Passenger window falls down
Old Oct 1, 2012 | 07:00 PM
CorvetteSPAZ's Avatar
CorvetteSPAZ
Default Passenger window falls down
I'm not familiar with the window, but it seems to drop down. I noticed this first when I had water all over my passenger seat.
When I pull the window up, it falls down, and the up and down buttons don't work.
I pull the door panel off, and took a look inside, and it looked like a cable with a blue end on is not connected.
I'm not too familiar with everything, can anyone explain what is broken based off this evidence?
Thank you
Old Oct 1, 2012 | 09:37 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
this post will help you start your replacement or repair.
http://forums.corvetteforum.com/c5-t...wr-window.html
I had the recent fun of rewinding the cable on the spool. It was a choir getting the tension correct and the cables back on.
I would recommend u visit rockauto.com
Old Oct 1, 2012 | 09:43 PM
DIXZ's Avatar
DIXZ
You need to replace the window regulator. It is not that bad of a job, as you already have the door panel off.
To Passenger window falls down
