LS7 cam in a LS6?
Old Oct 5, 2012 | 06:58 PM
anothertoy's Avatar
anothertoy
Default LS7 cam in a LS6?
Is a cam taken out of a LS7 able to be used in an LS6 or is there modifications necessary?
Old Oct 5, 2012 | 07:48 PM
WKMCD's Avatar
WKMCD
You'd have to go with a single bolt timing set but it will physically fit. The question is why would you run a cam designed for a COMPLETELY different head with COMPLETELY different port design.
Old Oct 5, 2012 | 07:59 PM
Dave concrete's Avatar
Dave concrete
I don't see the reason the LS6 cam is a real good matched cam for your gearing. I don't know if the benefits if any would be worth the time.
Old Oct 5, 2012 | 08:00 PM
NukeC5's Avatar
NukeC5
Agreed. All the work involved in changing the cam, you might as well go with a cam that's designed for the engine.
Old Oct 5, 2012 | 08:12 PM
WKMCD's Avatar
WKMCD
It's also designed for 1.8 ratio rockers. The LS1/6/2/3 all run 1.7.
I would bet a dollar that it will actually decrease performance.
Old Oct 5, 2012 | 11:15 PM
anothertoy's Avatar
anothertoy
It's actually a custom cam that was just taken out of an LS7. I was just wondering if it would work. I guess I'll just go with a new one. I'll start a new thread for that. Thanks for your help, guys!
Old Oct 6, 2012 | 10:17 AM
robert miller's Avatar
robert miller
our cars dont like the 1.8 rockers there has been alot of problems with them on the ls1 and ls6 heads...I wouldnt take the time r money with that cam dont see it helping you at all for the work you will be putting into it.....Robert
To LS7 cam in a LS6?
