Wipers wont stop
Old Oct 6, 2012 | 08:13 PM
m6 c5's Avatar
m6 c5
Default Wipers wont stop
Ok I give up on searching as Ive read several threads and cant find anything exactly like my problem. Ive already cleaned out the circuit board but I didnt see any water anyways. Nor have I driven in the rain in a few weeks.
Well when I started my car a few days ago they started going at low speed and stayed on for several min and then started working like they should. Today they did the same thing and I ended up pulling the fuse I can turn them on high but thats the only option I can choose besides the low speed. Is there anything that would cause this besides water or the wiper switch going bad, could it be a ground or did something go bad in the motor?
Old Oct 6, 2012 | 08:19 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
It sounds like the multi-function switch is bad. Easy to replace but expensive.
rr
Old Oct 6, 2012 | 08:37 PM
lucky131969's Avatar
lucky131969
Any troubleshooting with a meter/schematics, or did you just pull apart the motor?
Old Oct 6, 2012 | 08:42 PM
m6 c5's Avatar
m6 c5
I just pulled the motor out as Im not very good with electrical stuff at all and am very rusty on schematics so I really wouldnt know where to start with it.
Old Oct 6, 2012 | 08:49 PM
lucky131969
Well, for this type of stuff, you need to reach out....can save you a lot of time and money. The windshield wiper switch controls the voltage to the motor assembly. Easiest thing to check, is voltage at the motor connector. With the wiper switch in the "off" position, you should only have voltage on pin B....if there is voltage on any other pin, you either have a bad switch....or 12 volts shorting somewhere.
Old Oct 6, 2012 | 09:08 PM
m6 c5's Avatar
m6 c5
Ok so I just went and checked and with it in the off position I have 12 volts at B and if Im not mistaken D which is grey then as I go up to the first position I get ~7 volts on what I assume is E according to the diagram with it on long delay which goes up to 12 on short while still getting 12 volts through B and D. Then on low I get 12 volts at B, D and E. On high I get 12 volts on E as well A read zero the entire time which I guess is the ground.
Old Oct 6, 2012 | 09:19 PM
lucky131969
This should help......
Old Oct 6, 2012 | 09:29 PM
m6 c5's Avatar
m6 c5
Looks like I just had a typo for the last one where it should have been C that I was getting 12 volts through with the switch was on high. SO i had 12 volts on B and D in the off position. Delay I got power on E ranging from 7 volts to 12. On low I got a fixed 12 on E then on High I got power on C.
Old Oct 6, 2012 | 09:34 PM
lucky131969
Ok, well done. Now were getting somewhere. There should not be 12 volts on B and D in the off position. Two possibilities:
1) A contact for the washer switch is stuck, allowing 12 volts to pin D
2) The left most switch in the schematic is shorted.
Old Oct 6, 2012 | 09:37 PM
m6 c5's Avatar
m6 c5
Ok so how do I go about figuring out which one is my problem and how can I fix/repair it.
Old Oct 6, 2012 | 09:44 PM
lucky131969
Everything is contained in the switch, so I can only see one more isloation point:
1) Pull fuse #10
2) Wiper switch to off position
3) Measure the resistance between pin B and pin D of the motor connector
4) Measure the resistance between pin B and pin E of the motor connector
5) Measure the resistance between pin B and pin C of the motor connector
Old Oct 6, 2012 | 09:55 PM
m6 c5's Avatar
m6 c5
1) Pull fuse #10
Ok I get a small amount between B and D and no reading at all through E and C.
Old Oct 6, 2012 | 09:59 PM
lucky131969
How small between B and D? In other words, a dead short would be .3 ohms or less.
Old Oct 6, 2012 | 10:08 PM
m6 c5's Avatar
m6 c5
Ok well I got .1 on the 200 ohm setting
Old Oct 6, 2012 | 10:11 PM
lucky131969
Ok. That suggest to me, that one of the contacts(internal to the switch) for the washer is shorted(stuck). So, you can try depressing the button rapidly, while the meter is connected between B & D, and see if it changes to open (or no resistance).
Old Oct 6, 2012 | 10:15 PM
m6 c5's Avatar
m6 c5
When you say button do you just mean to move the stalk down for the single swipe function or up to the delay?
Old Oct 6, 2012 | 10:19 PM
lucky131969
No. There is a push button at the end of the stalk. That is for the washer fluid.
To Wipers wont stop
Old Oct 6, 2012 | 10:32 PM
m6 c5's Avatar
m6 c5
It opens up very briefly and then goes right back.
Old Oct 6, 2012 | 10:36 PM
lucky131969
Sounds to me like you have isolated it to the wiper switch. Good job sir. For someone who says they are not good with electrical stuff, you did a great job isolating this issue.
Old Oct 6, 2012 | 10:53 PM
m6 c5's Avatar
m6 c5
Well if I have someone telling me how to do it then its easy, anyways does that mean I have to replace it or can I tear it apart and fix it?
