Help!!! Dead battery?
Old Jun 4, 2002 | 09:04 AM
superdave's Avatar
superdave
Default Help!!! Dead battery?
I had no problem opening the trunk and unlocking the doors this morning, but then everthing went dead before I could turn the key all the way over to ignition. WTF?
The Optima red-top battery is less than a year old. I had no problems yesterday or during a road trip this past weekend.
It's not as if I left the lights on or anything like that last night. I don't have anything plugged into the cig. lighter.
How did I drain the battery (if that's the problem)? Will a jump-start be a sufficient long-term solution?
My daily driver died last week, so this is a good excuse to take a day-off from work. ;)
Old Jun 4, 2002 | 02:17 PM
ersatz928's Avatar
ersatz928
Default Re: Help!!! Dead battery? (superdave)
You need to do a "Key-Off" current draw test, with a milliameter. It should be less than 100mA after when the car is in "sleep Mode" (key off, and out of lock cylinder, doors closed, takes about 15 min to go into sleep) I have heard of some defective CD changers which draw too much current when they are supposed to be off. Try unplugging that.
Old Jun 4, 2002 | 03:38 PM
superdave's Avatar
superdave
Default Re: Help!!! Dead battery? (ersatz928)
Thanks for the tip!
Stupid question - where do I place the multimeter probes for a current draw test?
Old Jun 4, 2002 | 04:21 PM
Fast one's Avatar
Fast one
In series with a battery cable; remove either + or - and place one lead on the battery and the other on the cable, never across the battery. After a minute the reading should be about 20 ma. Make shure to remove the underhood bulb first.
Old Jun 4, 2002 | 04:44 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Fog lights were not left on, right!
Opitima's go bad too!
Old Jun 4, 2002 | 10:46 PM
MDT's Avatar
MDT
Default Re: Help!!! Dead battery? ()
superdave,
You may want to check the battery post connections for cleanliness and tightness. Also place a volt meter across the battery post with the engine running to make sure the alternator is charging; should read around 14 volts.
Compare the reading that you get with the DIC reading.
Place the voltmeter across the battery posts with the engine not running. A fully charged battery should read around 12.65 volts. If the alternator is charging and the battery is low....take Al's advice.
Good luck.
Mark
Old Jun 4, 2002 | 11:04 PM
Diamond's Avatar
Diamond
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Help!!! Dead battery? () (MDT)
I was gonna tell you to scrap that A/C Delco and go with an Optima, whoops. :eek:
To Help!!! Dead battery?
