Leaky Butt fix?
Old Oct 7, 2012 | 08:39 PM
SSTG's Avatar
SSTG
Default Leaky Butt fix?
Has anyone tried this and did it work? Any Ill affects from using it?
http://www.amazon.com/White-Shepherd...pr_product_top
I also read on here to use Redline 75W90 HP gear oil to stop the leak.
Mine doesn't drip on the floor but I did see evidence on the cross member.
Thanks Guys!
Old Oct 7, 2012 | 11:07 PM
fwrogg's Avatar
fwrogg
the reviews seem to support it working.
Old Oct 8, 2012 | 08:13 AM
SSTG's Avatar
SSTG
I'm nervous that it might cause some kind of damage? I know someone on here has tried it I'm sure.
What about the Redline oil? Has that helped anyone?
Old Oct 8, 2012 | 08:52 AM
bumble-z's Avatar
bumble-z
Using Redline gear fluid will not eliminate an axle seal leak.
Old Oct 8, 2012 | 12:50 PM
SSTG's Avatar
SSTG
Thanks BZ.
Anyone use the White-Shepherd?
Old Oct 8, 2012 | 01:02 PM
ZeeOSix's Avatar
ZeeOSix
Thanks Guys!
Could be it's just the differential vent puking fluid now and then.
To determine exactly where the leak is coming from, you'll have to clean up all the residue and then drive it a bit and reinspect to see where the new fluid shows up. If it's an axle seal, you'll see that pretty clearly with the inspection.
Old Oct 8, 2012 | 04:28 PM
carpe dm's Avatar
carpe dm
To Leaky Butt fix?
