shutoff problem
Old Oct 9, 2012 | 06:39 AM
Acloud's Avatar
Acloud
2nd Gear
Default shutoff problem
I have a 2003 C5 manuel 6 speed I have had problems with the car not starting
Looks like dead battery problem even though it has been on a battery tender. You can hookup jumper cables you hear a click and it starts fine.
Current issue Car starts fine and idles fine you can rev the engine in neutral as long as you like every thing is fine if you put the car in 1st or reverse the car will move a few feet then the engine dies like you have turned the switch off. Put it in neutal it will start right up.
any idea's or help?
