I'm planning on pulling about 4 to 6 degrees of timing when the car is on the gas (150-shot), using an on-off switch wired to the IAT sensor.
I've heard a few people mentioned that too much timings can also burn your exhaust valves. Can someone please give a detail epxlaination on what happen when you pull too much timings?
Re: What happen when you pull too much timings??? (Tuan Le)
Tan Lee,
If you are running at least 91 Octane gas then there is NO reason to pull ANY timing with only a 150 shot. 6 degrees would be WAY too much even if you had a 200 shot. 4 degrees would be acceptable with a 200 shot. Anything more would be excessive.
Pulling timing will really slow you down. It will kill your power.
Good luck!
And remember - you have a knock sensor that pulls timing for you if you suffer from detonation.
[Modified by EdwardETraylorIII, 11:03 AM 6/4/2002]
Re: What happen when you pull too much timings??? (EdwardETraylorIII)
Hmmm..I remember seeing it somewhere....where they recommend to pull 2 degrees of time per 50-shot.....
I would hate to depend on the stock knock sensors when spraying a large shot. It would have to detonate first before the knock sensor can pull timings, by then...it would be way too late.
"They" can speculate all day and night on how much timing to pull.
a 150 shot is not a "huge shot." If you were trying to spray 200/225 on your stock motor - then that would be a "huge" shot and require 4-5 degs of timing pulled!
I'm giving you real world results. I've sprayed over 10 automobiles of MY own (race and street) that have run from mid 8 to high 12's..... I've never pulled any timing on a 150 shot on an LS-X motor...... I've installed probably close to 100 kits on various customers and friends cars. Never have I needed to pull timing.
Do this for yourself.. Put a 150 shot on, make a pass with AT and see if it shows any knock retard? 99/100 times it won't.................... ( and that 1/100 time that it does - it will probably have been valvetrain rattle aka false knock...)
Good luck! :seeya
EDIT: attached sig...
[Modified by EdwardETraylorIII, 11:26 AM 6/4/2002]
It was Julio@Cartek who told me not to ratard timing too much or I would melt the exhaust valves.
Did he explain why?
Is it because when it ignite too late, the pistons are on the way down and may suck back in some of the hot air through the exhaust valves? :confused: :confused: :confused:
It was Julio@Cartek who told me not to ratard timing too much or I would melt the exhaust valves.Did he explain why?
Re: What happen when you pull too much timings??? (Austrian Vette)
Hey Michael,
What size of resistor did you use and what is the IAT temp when you flip it on?
On mine, the IAT reads 151-degree with a 560ohm 1/2 watt resistor. And timing was around 20 to 23 degrees. I think I'm going to replace with a 680ohm resistor bump the timing up few more degrees.
Hey Michael,
-Tuan
For me it didn´t work to only turn the temps to hot.
It didn´t retard timing equal how hot the resistor showed.
So I set the timing retard table for hot temps to 5 degrees and that retards
me the timing 6 degrees whenever I flip the switch.
However, so it works for me and the 25 seem to be perfect.
Car runs faaaasssstttt :D
