Problem with WCC wheels!
Old Jun 5, 2002 | 01:21 AM
CFast5's Avatar
CFast5
Default Problem with WCC wheels!
I am experiencing quite a bit of wheel shimmy after my tire shop installed my Y2k wcc wheels...Gets pretty bad past 70mph. My shop said they were all perfectly balanced and that the wheels were hopping around a lot on the balancer! Anyone else experience this or have a cure?
Old Jun 5, 2002 | 02:34 AM
bparker's Avatar
bparker
Default Re: Problem with WCC wheels! (CFast5)
Try having them balanced at another location.. :cheers:
Old Jun 5, 2002 | 02:35 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
The tire shop should be able to tell you, if the wheels are out of round. You might have to send them back, they should not hop around on the balancer.
Old Jun 5, 2002 | 06:01 PM
HIGHRPM's Avatar
HIGHRPM
Default Re: Problem with WCC wheels! (wallstAL)
Check the tires for damage or irregularities....I doubt its the wheels....they are made on a CNC machine and are extremely accurate.....
Old Jun 5, 2002 | 09:41 PM
Bobby B's Avatar
Bobby B
I've had my WCC Chrome OEM 2001 wheels for a year and have had no problems. They were installed by WCC.
Old Jun 5, 2002 | 10:42 PM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
I've had the same situation with stock 18" wheels on a previous 97 VR4. The outter circumference (round) had been damaged causing the wheel hop. The balancing machine detected nothing. But, if you put a dial indicator on the outside circumference, and slowly turn the wheel while it is on the balancing machine, you can measure changes in the outside radius which is called runout.
Old Jun 6, 2002 | 12:10 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: Problem with WCC wheels! (JTE)
Yes, the CNC machine can do extremely close tollerance work. But all it takes is one small metal chip on the clamping fixture, and you have runout. This happens regularly with disc brake rotors.
Old Jun 6, 2002 | 12:59 AM
flynbludream's Avatar
flynbludream
Call WCC and see if they are still under warranty. :D
Old Jun 6, 2002 | 01:04 AM
bruce1's Avatar
bruce1
Out of round tires..... has to be........Ditto Wallstreet.........IMO.
Old Jun 6, 2002 | 02:09 AM
Da Kind's Avatar
Da Kind
Default Re: Problem with WCC wheels! (flynbludream)
No they are not under warranty.
He was racing :lol: :lol: :lol:
He should have read the (non) fine print :lol: :lol:
Old Jun 7, 2002 | 12:40 AM
Joel Fromkin's Avatar
Joel Fromkin
Got chrome wheels from WCC for my 98,00,and now on my 02. Never a problem here. :cheers:
Old Jun 7, 2002 | 12:42 AM
AP's Avatar
AP
Default Re: Problem with WCC wheels! (Joel Fromkin)
If they arent using a Hunter Balance Machine ... go somewhere else ...
Old Jun 7, 2002 | 12:45 AM
allanlaw's Avatar
allanlaw
I had a similar situation with my stock wheels. It turns out that one of them had been damaged somehow on the road and was out of round. This condition can be detected if the tire shop uses a Hunter 9700 balancer. Go somewhere that has one (usually Discount Tires or American Tires have them) and let them try to balance the wheels.
Old Jun 7, 2002 | 07:04 PM
C6VETTE4FUN's Avatar
C6VETTE4FUN
It is the wheel balancing, Had the same issues after I replaced mine with Y2k wheels.
chris
Old Jun 7, 2002 | 08:13 PM
Rhynos99's Avatar
Rhynos99
Default Re: Problem with WCC wheels! (1997C5VTBOY)
Got mine from WCC 4 months ago and no probs :flag
To Problem with WCC wheels!
