Wrong MAF?
Old Oct 18, 2012 | 09:57 PM
bracketshark's Avatar
bracketshark
Default Wrong MAF?
While installing my vararam intake system today I went ahead and installed the 5 pin MAF I bought from a forum member, the P/N on this maf is 3409984. I bought a adapter from Racetronics, P/N MAF-001. Problems arose when i tried to plug the cable into the maf, the cable is to wide to plug into the maf. Which one is the incorrect part? Thanks
Old Oct 18, 2012 | 10:01 PM
lucky131969's Avatar
lucky131969
MAF-001 - MAF Adapter 3-Wire + IAT > 5-Wire GT150
This adapter harness allows for plug and play installation of a late-model GM / Delphi 5-wire MAF using the wide-spaced GT150 Series connector (2006+ Z06 Corvette) in a 3-wire MAF car. (98-02 LS1 Camaro / Firebird). The air temperature sensor (IAT / ATS) connector uses the standard Delphi Metri-Pack 150 Series connector found on the majority of GM vehicles.
Old Oct 18, 2012 | 10:20 PM
bracketshark
Damn you know some stuff, thanks for that information. One more question should i get another harness or try to find a MAF to fit the harness I've got? Suggestion Please.
Old Oct 18, 2012 | 10:51 PM
lucky131969
Ok, here's what's weird. The connector (plug) for a 2001 corvette, and a 2006 corvette, are the same part number.....15305555(delphi). The part number MAF you have, is for a 2001 Z06. So something is not right with the harness.
To Wrong MAF?
