I can kick myself
Old Oct 24, 2012 | 07:41 PM
tramminc's Avatar
tramminc
Default I can kick myself
I was trying to set top dead center by put the tip of a plastic pen in the spark plug hole, and then i heard a light noise. I pulled the pen out and saw the tip broken off. I threw both hands in the air and walked out of the garage.
Do I have to pull that head off just for that plastic tip.
Old Oct 24, 2012 | 07:45 PM
lucky131969's Avatar
lucky131969
Last time I checked, the only only two items permissible in the combustion chamber:
1) Air
2) Fuel
Old Oct 24, 2012 | 07:58 PM
1BADLS3's Avatar
1BADLS3
Fire it up, it'll burn up and go out the exhaust.
Old Oct 24, 2012 | 08:07 PM
tramminc's Avatar
tramminc
That may be true, it a very tiny plastic piece.
Old Oct 24, 2012 | 08:11 PM
1BADLS3's Avatar
1BADLS3
Whatever doesn't burn up (likely nothing left) will go out the exhaust valve and get caught in your catalytic converter, where it will burn the rest of the way.
Old Oct 24, 2012 | 08:25 PM
red89c4's Avatar
red89c4
you might try to fish it out with a sticky substance on the end of screwdriver. you might get lucky?
Old Oct 24, 2012 | 08:41 PM
tramminc's Avatar
tramminc
Got some out with a small vacuum, there a tiny piece left.
Old Oct 24, 2012 | 08:49 PM
whisperinsam33's Avatar
whisperinsam33
If the pen still writes well (all tip parts still there) you should be safe in cranking it up.
Old Oct 24, 2012 | 08:53 PM
tramminc's Avatar
tramminc
Thanks for you guys advice.
To I can kick myself
