Head light issue
Old Oct 24, 2012 | 07:51 PM
Brian O's Avatar
Brian O
Default Head light issue
I know this is a common thread about issue's with headlights. My driver side is popping up when turning them off. The reason I'm asking for help is about a year ago I rebuilt the head light with new brass gear kit. Everything worked great for about a year. Just this past weekend it started again. When I checked the the motor and shaft I found the shaft had about 1/4" play. So instead of rebuilding again I spent $160.00and bought a new motor. The problem is it is still popping up. Has anybody come across that problem? The rubber bumpers still look ok.
Old Oct 24, 2012 | 09:26 PM
Brian O's Avatar
Brian O
Fixed it. Thanks for looking.
Old Oct 25, 2012 | 01:02 PM
Louisiana vette man's Avatar
Louisiana vette man
what was the fix?
Old Oct 26, 2012 | 09:43 PM
Brian O's Avatar
Brian O
I had mentioned that there was about 1/4" play in the shaft,that drives the linkage up an down. When I turned the lights on the linkage that moves the lights up and down must of went past the stops, because of the play in the shaft. I didn't realize it when I installed the new motor. After taking some time looking at it is when I saw the problem. I just changed the linkage position and everything is work fine.
To Head light issue
