Started the Head and Cam Project....
Old Jun 5, 2002 | 07:17 PM
Phil97SVT's Avatar
Phil97SVT
Default Started the Head and Cam Project....
Well I finally got all of the parts ordered for my head and cam upgrade. I posted a week ago about what I had planned and it seems to be turning out better than I expected as far as price goes. Here is what I ordered:
Comp Cams timing chain
Rev Stainless Steel Valves(2.02/1.57s || cut stems)
Rev Seats/Locators
Rev Titanium Retainers
Rev Dual Valve Springs >.600 lift :lol:
MMS 229/229 .578/.578 114lsa :rolleyes:
LS6 intake manifold with hardware
LS6 2002 cylinder heads 625/ea :eek:
LS6 2002 Keepers
LS6 2002 Intake valve seals
LS6 2002 Exhaust valve seals
LS1 Cylinder head bolts
LS1 Cylinder head gaskets
Column Lock bypass (one of four left) :yesnod:
ASP underdrive pulley/belt ;)
<waiting to order> Cartek Clutch/SLP billet steel flywheel
I am going to have one of the local pro stock motor builders help me with the cylinder head. Basically, I ended up with a built LS6 heads for 1700. Any words of wisdom or things I missed. What kind of lube do I need to use on the cam when I install it? I have seen pictures of people using a white or a red lube. <shooting for 10s on the bottle> :yesnod:
[Modified by Phil97SVT, 11:18 PM 6/5/2002]
Old Jun 5, 2002 | 07:21 PM
vstella's Avatar
vstella
Default Re: Started the Head and Cam Project.... (Phil97SVT)
:eek: WOW!! Your not foolin around....You building a monster ?
With your new power your gonna need some traction :yesnod:
Old Jun 5, 2002 | 07:35 PM
Phil97SVT's Avatar
Phil97SVT
Default Re: Started the Head and Cam Project.... (vstella)
I have already hired two guys for traction. Mickey and Thompson. :lol:
If anyone is interested here is our plan for the heads:
1> Port match intake to intake manifold
2> Port intake runner to matched intake inlet 1-2" into runner
3> Port/polish valve guides/pockets/bowls/short side runner(intake/exhaust)
4> Port/polish exhaust runner removing
5> Port match exhaust runner to LT header
6> Polish combustion chamber
7> Smooth edges on combustion chamber
8> Machine shop => Valve job/prepare head for larger heads
9> Mill head .030
10> Intake valves to be machined on lathe
I guess I would be very optimistic to see 460rwhp like Cartek but I am shooting for 430-450rwhp after its dyno tuned. Cheers! :cool:
Old Jun 5, 2002 | 08:42 PM
jmX's Avatar
jmX
You dont need cam lube. Just put a little motor oil on the cam before insertion and you are set to go. I just installed my heads...its about a 6-7 hour job or so. Piece of cake.
Old Jun 5, 2002 | 11:47 PM
Shawn84&92's Avatar
Shawn84&92
Phil,
I am in the middle of my head and cam project now, I hope to get a lot done this weekend. I have the heads, crank puley ,front cover, and rack off, I hope to swap cams and start going back together with it on Saturday.
Good luck with yours, several guys on the forum have been a great deal of help.
Shawn
Old Jun 6, 2002 | 02:03 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
if you are going to mill .030 off the heads you may have piston to valve clearance problems with that big cam.
Best of luck, sounds like a fun project :)
To Started the Head and Cam Project....
