New Headlight Bulbs
Old Oct 28, 2012 | 07:36 PM
chuckrbt's Avatar
chuckrbt
Default New Headlight Bulbs
I searched this forum and can not find an answer to my question. The headlight bulbs on my 98 are original and it is time to replace them. What I would like to know are the higher wattage bulbs really better? If I install them, do I have to make other changes to the wiring/ballast?
Thanks in advance for your help.
Chuck
Old Oct 28, 2012 | 07:44 PM
Todds427's Avatar
Todds427
St. Jude Donor '12
To my knowledge, you can replace your headlight bulbs with stock bulbs, or a Sylvania Silverstar bulb which is direct fitment and a step brighter than stock, or you can use HID and you will need a kit with bulbs and ballast, these are the brightest and actually use less power. The key is how bright do you want to go? I think 4300k is equal to sunlight? I have 6000k and they are PERFECT.
Old Oct 28, 2012 | 09:49 PM
jcgunn's Avatar
jcgunn
Originally Posted by 8VETTE7
Depends..........
I'm running 80W low beams and 100W high beams with the factory wiring on my 2004 with no problems over the past 4 years. Factory are 55 and 65 IIRC. Not as good as projector setups but when I have the extra $$$ I'll go to those.
Where did you find 80/100W bulbs? and what brand?
Old Oct 28, 2012 | 10:33 PM
_r2h's Avatar
_r2h
http://www.candlepowerforums.com/vb/...?87-Automotive
Take a look there. IMHO, to stay remotely DOT compliant with the stock housing best you can get are HIR bulbs. Higher wattage bulbs and HID in the stock housing aren't DOT compliant.
HID in a retrofitted projector housing is kind of a grey area.
I put HIR bulbs in the girlfriends car and they were a marked improvement over the older stock bulbs.
Old Oct 28, 2012 | 11:26 PM
Tron Z's Avatar
Tron Z
IMHO, the lenses & reflectors in the OEM headlamps are not all that brilliant ... no pun intended. Brighter bulbs are only marginally better, because the light is not focused in a helpful manner.
If you don't want to spend the big $'s on projectors, see if you can still find the export H4 assemblies. These do a much better job of focusing the light where you need it and there are a wide variety of H4 bulbs available in various wattages.
Old Oct 29, 2012 | 12:09 AM
cookie7's Avatar
cookie7
Try here.http://www.corvettemods.com HID's at really good prices
Old Oct 29, 2012 | 01:10 AM
corvettemods1's Avatar
0corvettemods1
Former Vendor
St. Jude Donor '12-'13
Old Oct 29, 2012 | 07:31 AM
Oldvetter's Avatar
Oldvetter
I put silverstars in mine, they are better than stock. I also put in 855 fog light bulbs, they are 50 watts (stock are 37 watts).
If you are considering HIDs, consider putting them in your fog lights. The foglights are projectors with a sharp cutoff, when aimed properly (and with more light) they can be a great help.
Old Oct 29, 2012 | 12:00 PM
callie454's Avatar
callie454
Short of HIDs, your best option is a set of HIRs. Not sure if I can link to a non supporting vendor here, so PM me for my favorite. Hope this helps!
Old Oct 30, 2012 | 12:32 PM
bighank's Avatar
bighank
Default Did the same and the 885 fogs are much brighter
Quick and cheap way to get more light if not going to HID>
To New Headlight Bulbs
