Trans tunnel plate dimensions?
Old Oct 31, 2012 | 02:21 PM
The Mountain Kat's Avatar
The Mountain Kat
Default Trans tunnel plate dimensions?
Hey guys,
Can anyone tell me the dimensions of the C5 tunnel plate? Width and Length is what I need so the I can purchase a piece of aluminum. Sure I can jack her up and measure myself and I will if I have to but if someone knows off-hand it would sure save me some time and trouble.
Thanks!
Old Oct 31, 2012 | 03:01 PM
NukeC5's Avatar
NukeC5
Just went out and measured my left over stock one in the garage for you. (Replaced it with a C6 Plate).
It is 42.5" long and 12.5" wide at the widest section in the rear.
Old Oct 31, 2012 | 04:36 PM
NukeC5's Avatar
NukeC5
How thick are you planning to go?
Old Nov 1, 2012 | 02:54 PM
The Mountain Kat
Thanks for the measurements!
I'll pick up a bar of 3/8" or 5/16". I have plenty of thermal barrier products as well.
Anyone want a How-to done as I make the piece?
Old Nov 1, 2012 | 05:40 PM
olbear1962's Avatar
olbear1962
Always interested in seeing DIY projects, very cool!
Good luck and looking forward to seeing the finished results
Old Nov 1, 2012 | 08:01 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I used 3/8" and it makes a huge difference!!! Remember to pick up longer bolts for the install.
Old Nov 3, 2012 | 11:23 AM
CalixEros's Avatar
CalixEros
I did the same thing a several years ago. I got an AutoCAD drawing of the plate from someone on this forum that I used. Unfortunately I've since deleted it, but try the search function and see if you can find it.
To Trans tunnel plate dimensions?
