What to do with intake...
I'm sure it would be as simple as obtaining the kit for a later model that would have the diameters matched to the 85mm MAF. But I'm not about to order one without knowing for sure and not really willing to pay for another K&N intake new...
So basically what Im looking at here is obtaining an air-bridge and filter with larger diameter inlets and outlets. This way I can run a 3.75" ID straight coupler 2" long from the filter to the MAF and from the MAF to the air-bridge. Instead of screwing around with finding proper fitting reducers, (which is not looking good). They are all 3" long. And they are necking down to the old diameter which means they are now the restriction.
I found out by looking at filter numbers that the filter I have has an 89mm outlet and the LS6 style filter has a 98mm outlet. I cant find any info on the difference between the air-bridges, but Ill bet the later one has a larger diameter too.
So I guess with the 85mm MAF I can go with any intake I want, but I will have to order as if I have a later model car to get the size that fits the 85mm MAF
. It might be a good time to go with a Vararam B2 system... Still undecided. What to do? Any suggestions? I really do like the K&N and wouldn't mind upgrading to the later style for the right price.. I could always try to sell my current intake setup..
Will the larger diameter air bridge fit the early style coupler (throttle body to airbridge) or are you changing that as well?
It just could be that the TB with the blade in the middle of it flows the least.
Ditto for the MAF.
Wouldn't it be fun to put each on the flow bench and see?
This makes me very hesitant to but the kit. Did not all 2001 and newer base and Z06's have the 85mm MAF? The instructions are all different and clearly for that particular system, as well as the parts list. Why would the couplers be measured at 3.5"? I measured the 85mm MAF I have, and 3.75" is needed. How do these kits work for anyone with an 01 and newer C5?
I already spoke to K&N directly about this whole ordeal. They were no help
Now the choice is between part number 63-1050 and 57-3035... The only difference is that the 63 series supposedly has a smoother bridge. But again, the part numbers for the bridges are the same in these two kits and they use the same filter. Plus my early model 57-3020 is smooth as glass on the inside... Something tells me they all have this technology now.
Anyone know if the 63 series is worth paying more for? It is supposedly for the Z06 and the 57 series is for the base model. But there is no difference other than the air bridge from what I have researched. And like I said. The kits have the same part number for those...
http://forums.corvetteforum.com/c5-t...fications.html
I'm not thrilled with the K&N intake being half way through the radiator cover. I'm looking to keep the filter completely below / boxed in like my old Vortex. Guess the Vortex box could be widened to fit around the bigger K&N filter and something like a 22.5 degree angle fitting to tip the filter down lower.
If it is a 90mm or larger I may go this route. the setup I am close to doing would give me a 98mm filter outlet, an 85mm MAF, a 90mm TB, and a 92mm intake snout. So the MAF is still the smallest point in the intake. The LS2 intake and LS3/7 MAF leading into the TB/intake may give me a fully 90+mm intake...
The C6 K&N has a slot built in to accept the card type MAF and it is similar in price. It obviously will fit my LS2 TB well.
I guess all Id have to do is slap the new intake on and slide an LS3/7 MAF card in. How is tuning a card type MAF on the LS1? Does it also have the IAT integrated? The C6 intake wont bolt up like a C5 specific one, but I do have the shroud cut out too and Im sure I could get it it sit where I need it to...
Don't get me wrong, it sounds like a great setup, but even the LS6 style intake gives a 98mm filter outlet and very unrestricted system. I think I will be good with it and my FAST intake setup. Car will be seeing heads and a cam, but I cant even do long tubes here in Cail, so the intake will be better than what I need anyway I think.
