LS7 swap. Strange squeel.
Old Nov 7, 2012 | 06:50 PM
superramvette2's Avatar
superramvette2
Default LS7 swap. Strange squeel.
So we started the ls7 up today and it needs a tune. Well after running for a few minutes it started making a squeel that sounded like a belt squeel. We checked the belts and pulleys and it was not it. It only started about five minutes after cranking and it would only do it above 1500 rpms.
Here is a vid of startup. Yes there is blow-by it stopped bout ten minutes after running. The noise had not started yet on this video.
Well after the noise started and we were inspecting I pulled out the dipstick tube and it magically stopped. Reinserted and it started again. So we thought maybe the dipstick was hitting something maybe the crank(the block had to be drilled for a dipstick on the ls7. No signs of contact but no oil on the dipstick. Almost like it was cleaned off.
Well we cut the tip off the dipstick to see if it would work and it still did it. As long as the dipstick is out a half inch it does not do it. It is really weird and I am not sure what to think. Any ideas???
Old Nov 7, 2012 | 07:10 PM
Tron Z's Avatar
Tron Z
Sounds like you have a PCV issue. Have you provided some method of venting the crankcase?
Old Nov 7, 2012 | 08:41 PM
superramvette2
It has a pcv valve hooked up. I will inspect some more.
Old Nov 7, 2012 | 08:47 PM
Tron Z's Avatar
Tron Z
Good!
When you pull a vacuum on the crankcase, via the PCV valve, how does fresh (metered) air enter the system? That is the $64k question.
Old Nov 7, 2012 | 08:49 PM
superramvette2
Looks like you may be right. We need to reroute the flow to in front of the MAF sensor.
Old Nov 7, 2012 | 08:50 PM
Tron Z's Avatar
Tron Z
Actually, you need metered air, after the MAF sensor, but before the throttle plate. Typically, this air is plumbed into the RHS valve cover. GM has done this about eight different ways with the LS series over the years, so your particular hardware will dictate what will work on this specific engine.
Sounds like you are on top of it now.
Old Nov 8, 2012 | 01:01 AM
superramvette2
I assume it will be. It is at my friends house so I will not know until morning. Thank you guys so much for the help. I am taking it to the dyno tomorrow for tuning.
Old Nov 9, 2012 | 07:53 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
so this is a wetsump.
pan?
dipstick/tube pn/length?
where did you get info to drill block(regarding location)?
blowby? or moisture........
Old Nov 9, 2012 | 04:42 PM
superramvette2
Well rerouted pcv and it stopped. Finally got it to idle yesterday. Still needs a tune though. Not showing any knock going down the road (scaled injectors and a few little things with hp tuners).
Steve, it may have just been moisture. Whatever it was it did it the first few minutes and hasnt done it since. I will post another video of it idleing here in a sec.
Old Nov 9, 2012 | 10:45 PM
superramvette2
http://youtu.be/p3Q51ZtFaxU
Untuned other than injector scaling and idle tinkering.
To LS7 swap. Strange squeel.
