header install question
Old Jun 6, 2002 | 07:53 PM
KDubb's Avatar
KDubb
Default header install question
when going with TPIS full length headers and Bassani Xpipe, will i need to get any new sensors or anything like that ? ?
i have an 01 Z06
thanks
Old Jun 6, 2002 | 08:04 PM
TAMUz28's Avatar
TAMUz28
Default Re: header install question (KDubb)
If you are removing the cats from the equation, you will need some O2 simms to place in the rear O2 spots...otherwise, no, nothing else is needed. YOu will swap over the stock front O2's into the headers once they are installed...good luck! :smash:
Old Jun 6, 2002 | 08:05 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Not at all, use your old one. I even used my stock header gaskets
Old Jun 6, 2002 | 08:06 PM
KDubb's Avatar
KDubb
Default Re: header install question (TAMUz28)
ok, do i need this :
02 sims and TPIS H-fitting ?
Old Jun 6, 2002 | 08:12 PM
TAMUz28's Avatar
TAMUz28
You'll need the Hpipe....the only reason you will need O2 simms is if you plan on removing the cats, that is, having straight pipe welded in between the TPIS Hpipe and the Bassani...
Old Jun 6, 2002 | 08:22 PM
KDubb's Avatar
KDubb
what exactly does the Hpipe do ?
anyone got any pics of a set up like this ?
im wanting to go TPIS>cat/no cat (not sure)>bassani>stingers
Old Jun 6, 2002 | 11:16 PM
chevythunder's Avatar
chevythunder
the h pipe is actually your mounting flange that the headers slip into and being long tube headers unless you are relocating the cats, you will be loosing them therefore will also be needing the simms... i will try and get some pics tomorrow and will load them for u.
Old Jun 7, 2002 | 02:24 AM
JayDB's Avatar
JayDB
saturday i'm having tpis LT headers, maganflow x-pipe, and corsa indy daytonas put on
what is an O2 simm? will i need this? where do i get it?
thanks
Old Jun 7, 2002 | 03:08 AM
02C5's Avatar
02C5
email me at braft@popmail.com. Just got the TPIS's put in, got a shot that shows the weld at the h- pipe. You also have to cut about an inch of the midsection pipe after the cats, but I think with an X- pipe you can avoid the flaring cause your going to replace that whole section. OR tell me how to post pics.
[Modified by 02C5, 7:09 AM 6/7/2002]
Old Jun 7, 2002 | 03:53 AM
c5chris's Avatar
c5chris
I am curious about this topic too. I will be installing either the TPIS or the Stainlessworks headers onto stock cats and Bassani X-pipe. Dont you forego an H pipe for the X pipe?
Oh yeah, whoever has the stainless works headers, please chime in and lemme know how you like 'em
Old Jun 7, 2002 | 09:40 PM
TenaciousD's Avatar
TenaciousD
Default Re: header install question (c5chris)
The H-pipe is a connector between the two sides of the TPIS collectors BEFORE the cats, it should not be confused with the factory H-pipe which comes AFTER the cats (which is replaced by an X-pipe). I had TPIS headers installed today, and wonder why they need the H-pipe piece if you already have an X-pipe after the cats. Apparently it was ~1/8 of an inch off, and caused my installer all kinds of fits.
He had installed Stainless Works headers a month or so ago, and said they took about 2 1/2 hours less time (less things to remove, easier to line up as they have no H-connection).
[Modified by TenaciousD, 8:42 PM 6/7/2002]
To header install question
