Brake caliper Bracket Bolt?
Old Nov 13, 2012 | 08:43 AM
fc_soldier's Avatar
fc_soldier
Default Brake caliper Bracket Bolt?
Does someone know the specs for this bolt?
I'm looking for number 2
This image is for a fbody but I need this bolt for c5 brake system.
Old Nov 13, 2012 | 02:15 PM
c3andc5's Avatar
c3andc5
I can get the specs for you later tonight from my shop manual, but fyi, I couldn't find it anywhere including mulitple hardware stores and Fastenall. Was forced to get it from a Chevy dealer at $8/each.
Old Nov 13, 2012 | 03:00 PM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
Supposedly you can reuse the bolts IF you apply a drop or two of red thread locker on the bolts. Torque required is 125 #
Old Nov 13, 2012 | 03:11 PM
bumble-z's Avatar
bumble-z
Caliper pin bolts
(These are small bolts, & I believe are what you are refering to as #2 )
M8x1.25
GM part #14067559
Torque to 23 lb ft (Never over torque)
Caliper bracket mounting bolts (These are large bolts)
GM part number 14084051
Torque to 125 lb ft
Old Nov 20, 2012 | 08:35 PM
chris308's Avatar
chris308
So it's 2 of each bolt per caliper that should be replaced, is it the same for the rear calipers?
Old Nov 20, 2012 | 08:51 PM
bumble-z's Avatar
bumble-z
Yes,
for the rear, it's exactly the same two bolts per side.
Old Nov 21, 2012 | 07:53 PM
bighank's Avatar
bighank
Default Don't need to replace them
Unless you break them.
Old Nov 22, 2012 | 06:29 AM
LoneStarFRC's Avatar
LoneStarFRC
Did they give you a big kiss when they were done with you?
$4.20 ea at gmpartseastdotcom
HTH
Old Nov 22, 2012 | 08:55 AM
C5Natie's Avatar
C5Natie
Originally Posted by bumble-z
Yes,
Exactly, just the pins that the bolts go into are different front to rear. Just in case someone orders the bolt and pin set. Autozone carries them at about $7 per set.
To Brake caliper Bracket Bolt?
