Anyone have info on rebuilding 4L60's?? what can be done to make them stronger??
Cruise-In VII Veteran
I've got a 4L60 sitting here with 150k miles on it. (was planning to run it in my Z06 with some FI)
What are the weak points in the 60?
What areas need to be addressed?
I'm looking for it to handle 5-600whp without fuss.
While were at it, Yank or Vigilante for the TC, and what stall can survive 5000miles/year of abuse?
Thanks very much.
I'm aware of Rodney and the crew at RPMtransmission.com, I've installed dozens over the years, I would just like to learn more about the auto's
Thanks very much.
Thanks very much.
Thanks very much.
Too bad a 4L80 won't bolt into a C5...
There is a lot of good info on the internet if you google performance 4L60E.
Go here for a lot of good info. The 4L60E really got popular with the advent of the LS engine.
http://ls1tech.com/forums/automatic-transmission-13/
You aren't going to hear much good about Monster there I'm afraid.
Personally, I went with Performabuilt in my C5, a level 2 and it has been excellent. Also went with a Yank SS3600 converter. Vigillante is good, PTC is good, and so is Circle D. You need to spend some bucks if you want lockup to work at WOT.
I'm at about 3k miles and 50 dragstrip passes on my setup, no complaints.
You will either need to learn to tune transmission parameters yourself, of find an excellent tuner who can do it for you.
Ron
Ron
