LS6 intake manifold
Old Jun 11, 2002 | 07:03 PM
rbeckham's Avatar
rbeckham
Default Re: LS6 intake manifold (AZ99FRC)
That little tiny plastic vacuum hose that's impossible to get at. It's probably leaking or off all together. The hose sticks out of the wiring harness in the back and is easy to miss. Take the rubber right angled connector off the manifold and stick it on the hose. Then when you put the manifold back on you can reach behind and slip the connector on to the manifold nipple. The nipple faces straight towards the passenger side. Trying to slip the vacuum hose into the connector with it attached to the manifold is almost impossible.
Thanks Andy. As you were probably posting this, I was out in the garage pulling it back off. When I was typing my post, a light bulb came on over my head! Wait a minute, where was the small hose in back that the install posts mentioned? I didn't even see it when I pulled the manifold off...the rubber elbow was still attached to the old one. You're right too about putting the connector on the hose first, then on the manifold nipple. Easy fix and now my air is blowing strong again.
BTW...time of first R and R....3 hours+. Time to pull it back off and put it on again right (at 10pm in a hot garage)....under 1 hour. Amazing what experience does!
You'll know if this line is open if you run it for a day or two - you'll throw an emissions code (I think it was P1441?) and eventually the "check engine" light will come on. This happened initially with my install. BTW - I have done a succession of mods (most lately, Mallett ported LS6 heads and the 2002 LS6 cam, and these nowhere near the effect on performance compared to the original switch to stock 2001 LS6 parts. This is subjective; I have never had it dynoed.
Old Jun 11, 2002 | 10:38 PM
chuckster's Avatar
chuckster
Default Re: LS6 intake manifold (rbeckham)
Robert, Ever get your Shifter done? Have you had a chance to test it out?
Old Jun 12, 2002 | 10:54 AM
Heavyd's Avatar
Heavyd
Default Re: LS6 intake manifold (chuckster)
I just had an Ls6 manifold installed this weekend and it helped mine alot. I have the thunder 224 cam and was having idle issues witht the air on . Now that I have the LS6 inatke and a 160 thermostat. My idle problems are almost completely gone. The car seems to pull alot stronger too. The biggest thing I noticed was that the car seems to run A LOT smoother. I would highly recommend doing the Z06 intake if you are planning on going a cam istall. As far as stock goes there was a BIG difference between my 98 Z28 and my 01 SS so I think it would be a good stock booster as well. :cheers:
Old Jun 12, 2002 | 11:04 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Default Re: LS6 intake manifold (Heavyd)
I didn't use a PTB, but definite gains with an LS6 intake. I think it took Andy 15 mins to pull it off. I could do it in 1/2 hour.
Old Jun 12, 2002 | 11:11 AM
C5Noir's Avatar
C5Noir
Default Re: LS6 intake manifold (direland67)
Anybody with a 2001 (non Z06) that has gone to the 2002 LS6 intake? Is it worth it if you have not done the H/C on a 2001?
[Modified by direland67, 12:07 PM 6/11/2002]
All '01+ LS1's have the LS6 intake.
Old Jun 12, 2002 | 02:14 PM
Face's Avatar
Face
Default Re: LS6 intake manifold (C5Noir)
How does the truck manifold compare to the LS6?
Old Jun 12, 2002 | 05:01 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Default Re: LS6 intake manifold (Face)
Most of the extra hp on the Escalade is from the LS6 manifold.
Old Jun 12, 2002 | 06:03 PM
Crushinator's Avatar
Crushinator
Default Re: LS6 intake manifold (C5SilverBullet)
The LS6 manifold is a great mod! I just had one installed yesterday along with a set of longtube headers and there's quite a difference in how hard this thing pulls now above 3500 RPM. I realize my gains are probably a little more significant since my car is supercharged, but I can see where a stock LS1 would benefit from it too.
Old Jun 12, 2002 | 06:35 PM
AZ99FRC's Avatar
AZ99FRC
Default Re: LS6 intake manifold (QuickSilver97)
I agree. I just had mine 'after' dyno done at Extreme and gained 14rwhp and 11rwtq. Nate was mildly dissappointed with my numbers since he's seen as high as a 17rwhp gain, but my car was really running hot today. I picked up an Exteme coolant kit (Tstat plus fan controller) while I was there.
Can't seem to get out of that place w/o buying something! Nate did give me a freebie takeoff shift **** though so I'm a happy camper.
