Need help with engine vibration
2004 - Long tubes/X-Pipe/Cat Back (no vibration from this)
2005 - Moderately aggressive cam, ported heads, SLP aluminum flywheel/clutch/PP (vibration started here), new master and slave
2006 - Installed aluminum driveshaft coupler in the TT (front coupler only)
2009 - Installed an LS3 (engine was balanced) w/ a moderately aggressive cam, A@A SC, and moster stage 3 flywheel/clutch/PP new master and slave, poly engine mounts; removed the front aluminum driveshaft coupler and replaced with the stock rubber one (no change in vibration)
2010 - Installed a Z06 torque tube (no change in vibration)
The only thing that seems consistent is an aggressive cam and a non-stock flywheel. Will a lopey cam cause engine vibrations?
I've read that GM takes extra care in balancing the M6 models. Is there a way to replicate the GM drivetrain balancing process?
For starters, were all of the dowel pins present and accounted for? Are you using an OEM guibo joint that is in good condition?
Some clarification would also be helpful. When do you feel the vibration: driving down the road, driving with the transmission in neutral, driving with the transmission in gear and the clutch disengaged, sitting still while revving the engine? Can you reproduce the vibration with the rear wheels in the air?
FWIW, even though the engine is internally balanced, I have seen threads indicating that flywheels had to be match balanced when replaced, in order to prevent vibrations.
I am familiar with one manufacturer that bolts the engine and trans together and runs them on a stand prior to installation in the vehicle. They add weights (bolts) to the flywheel to balance the entire assembly. When replacing flywheels, it is necessary to transfer the bolts to the new unit. ** I have no idea whether GM does anything like this **
2. All the dowel pins are accounted for and installed properly. The OEM guibo joints are being used and in good condition.
3. The vibration is most often felt while driving. Gears 1-4 have the worst vibration. If driving in 4-6th gear around 1,500-2K RPMs the car is smooth. Any down shifting to 4th, 3rd, etc. from city or highway speeds seems to exacerbate the vibration. The vibration is worst in gears 1-4 while maintaining a constant speed or decelerating until under 2K RPMs. Quick accelerations seem to reduce the vibration. With the clutch disengaged the vibration comes and goes from 2-4K RPMs but gets very bad above 4K RPMs. I haven't tried with the wheels off the ground.
The strangest part is during a cold start the car is almost completely smooth for the first 5-10 minutes of driving throughout all gears and RPM ranges. Once the car is warmed up pretty good is when the vibration is the worst.
Regardless that the engine is balanced and the Monster is supposed to be zero balanced I guess it needs to be balanced as an assembly. I haven't been able to find anyone that can do this.
Search ebay and you'll find them.
Good Luck,
Alex
You said you replaced the torque tube and FRONT coupler. Have you replaced both couplers? If it was the clutch ,it would vibrate cold or hot.
Here is my thought. You have a bad coupler that is made out of stiff reinforced rubber.
It holds it shape better when its cold and stiff. After 10 minutes of run time it gets warm and loosens up a bit allowing it to run out of balance.
