Looking to add a Z06 rear spring to my FRC and I think I've found one. Need to make sure it's the right part number-I'm coming up with 22179020 from my parts search resource. Can someone confirm? THX.
EDIT-Now I'm confused. The above is listed as FE3 rear. There is also p/n 22188038 that is listed as FE4. Doing some reading says that the only difference between FE3/4 was shocks in '04. My FRC has the same front spring as the Z06. Which rear should I use?
