Help with no start
Old Nov 19, 2012 | 10:53 AM
mobius's Avatar
mobius
Default Help with no start
OK guys I have nofuel pressure. I can force the pump on through hptuners. there are no DTCS. when i key on pump comes on for a second then turns off. I saw where the crank position sensor can cause this but it appears to be working properly. ie when i try to start the car rpms run around 100... what will cause the pcm to not turn on the fuel pump?
thanks
Old Nov 19, 2012 | 11:25 AM
BigGun's Avatar
BigGun
thanks
Are you checking pressure by using a gauge on the rail?
Old Nov 19, 2012 | 11:34 AM
mobius's Avatar
mobius
Originally Posted by 8VETTE7
What is the security light doing when you try to start the car?? If the key is not read correctly the fuel pump doesn't get enabled but you should also get a DTC set.
It is solid then goes out. Opening door it just flashes security.
Old Nov 19, 2012 | 12:08 PM
mobius's Avatar
mobius
I have a fuel pressure gauge. It reads 60 then drops to zero. It is a return style system.
Scanned codes on DIC and only codes are related to ABS and a park lamp relay.
How does it work? does the pump turn on to build pressure then turn back off and pressure holds then when car starts pump turns back on? or does the pump stay on the whole time?
Old Nov 19, 2012 | 05:11 PM
mobius's Avatar
mobius
Bump
Old Nov 19, 2012 | 06:33 PM
Tron Z's Avatar
Tron Z
Affirmative; the PCM turns the pump back on, when/while it sees a signal from the crank position sensor.
The fuel pressure should hold for some time. If it doesn't you may have problems starting the engine after a hot soak.
Old Nov 19, 2012 | 07:23 PM
mobius's Avatar
mobius
Ok , fuel pressure drops immediately so that must be the problem , now just need to figure out why. But when i start cranking the engine it should turn back on right?
Old Nov 19, 2012 | 07:36 PM
mobius's Avatar
mobius
Should I force the fuel pump on with hptuners and try to start the car? To see if that is the problem?
Old Nov 19, 2012 | 09:14 PM
Tron Z's Avatar
Tron Z
You can try it, but if there is no signal from the crank sensor, the injectors will not fire, either.
Old Nov 20, 2012 | 06:29 PM
mobius's Avatar
mobius
OK so i commanded fuel pump on and no start still. Here are all the codes
tcs had 1214,1225,1232 and 1278 all H on the ends so not active.
no BCM or PCM codes
sdm had a u1016 H code and DCM 2252 H code
thats it. Nothing! On hptuners when cranking i was looking at rpm and crank cylinder current firng and crank sensor current cylinder
rpms were around 100
crank cylinder current firing seemed to be counting through 1-8
crank sensor current cylinder was changing but very high numbers it stopped on 5,460 and i saw 8k something as well. is this correct???
thanks
Old Nov 20, 2012 | 10:21 PM
mobius's Avatar
mobius
bump
Old Nov 21, 2012 | 07:53 AM
mobius's Avatar
mobius
any ideas?
Old Nov 21, 2012 | 05:07 PM
Tron Z's Avatar
Tron Z
I just had a look at you profile. It looks like there have been quite a few modifications to the car. Would you care to give us an overview of the mods? Additionally, what was happening just prior to the present concern? Was the car running fine and out of the blue wouldn't start, or did it die while driving, or are you in the middle of new mods, or etc.?
If you haven't already done so, have a look at your various temp sensors and ensure that the readings are plausible.
I personally have not seen a cam sensor failure on a C5, but I would check that you have a signal. Most engines will continue to run if the cam signal goes away, but many will not start without said signal. The WSM states only that there will be a long crank without a cam signal input, but I'm not sure what "long" means.
Can we assume that you have eliminated all of the mechanical possibilities?
Old Nov 21, 2012 | 06:43 PM
mobius's Avatar
mobius
Sure man it is a 408 lq9 block 9:1 compression with ls3 heads and intake with a YSI blower at 16 psi dynoed 900/820 on pump/meth. It has an A&A return fuel system. The meth pump was leaking so i sent it in for a rebuild. while waiting for it i soldered a new relay in the driver door control module as the door did not lock. the locks work now lol but after i insatalled the meth pump i went to start the car and nothing. prior to the two weeks it sat i turned the car on and moved it in the garage to put it on the ramp so it was only on for a couple of minutes. Hope this helps.
Old Nov 23, 2012 | 02:09 PM
mobius's Avatar
mobius
ok more info. I have spark and looking at a scan of trying to start the injectors are pulsing.
Is there a check valve in the fuel system that could be stuck open?
I dont think it is fouled plugs as it doesnt even try to start....?
To Help with no start
