VIN locations?
Old Nov 20, 2012 | 08:54 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Default VIN locations?
Did a search and couldn't find too much.
I'm looking at a car and I know the vin is on the left side of the dash, and stamped in the forward right frame rail.
I am under the impression it is stamped somewhere else as well. Am I correct?
Old Nov 21, 2012 | 01:28 AM
dblerman's Avatar
dblerman
It's also on the labels in the glove compartment and door jamb.
Old Nov 21, 2012 | 06:01 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
Anywhere else on the frame?
Old Nov 22, 2012 | 08:08 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Anyone else have info?
Old Nov 22, 2012 | 10:24 PM
Here's some info for a 2003 - not sure if it pertains to all C5s but I would guess so.
http://www.corvsport.com/Corvette/C5..._2003_VIN.html
Old Nov 22, 2012 | 11:58 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
On my '01, I have found the VIN stamped on the aft face of the frame's front cross member. I needed an inspection mirror to see it with the hood open. It looks identical to the stamping on the inside of the right front frame rail that the OP mentions
Old Nov 23, 2012 | 12:34 AM
RonSSNova's Avatar
RonSSNova
My 00 has it on the top of the front frame crossmember near the middle as well as on the side frame rail right where it joins the front crossmember.
Old Nov 23, 2012 | 09:53 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Pete, it's hit or miss, more often a miss towards the 2004 MY
the vin is etched on the front frame bar aft of the upper bumper support and the RHS frame a few inches back from the the 'face' of the frame
Those are the ONLY 2 spots on the frame I have seen the VIN
shoot me a txt if you need pics of the locations
Old Nov 23, 2012 | 10:14 AM
C5 Pete's Avatar
C5 Pete
AMP Racing
Thanks guys. I'll check these out.
To VIN locations?
