Problems filling fuel tank!
Old Jun 8, 2002 | 12:26 AM
CoolYellowOne's Avatar
CoolYellowOne
Default Problems filling fuel tank!
Ever since new, I cannot fill the fuel tank at a decent speed. The gas pump keeps stopping unless I fill at less than 1/2 speed. I've tried many different pumps at different gas stations, and it happens with all of them. It takes forever to fill up. Does anyone else have this problem? What causes this and how can they fix it?
Old Jun 8, 2002 | 09:32 AM
chocoholic's Avatar
chocoholic
Default Re: Problems filling fuel tank! (CoolYellowOne)
Seeing as no-one else replied, I hope this isn't too obvious, but have you tried not pushing the fuel nozzle right into the tank? Just back it out a half inch or so so that it reduces the back-pressure enough for the pump not to think your tank is full.
Old Jun 8, 2002 | 09:53 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
No problems whatsoever such as you describe. My only problem is that I love this car so much I find myself at the pump way too often! :lol: :lol: :lol:
Old Jun 8, 2002 | 11:46 AM
white93's Avatar
white93
No such problem ('99 coupe). Use a number of different pumps with different speeds and I don't pay attention to how far into the throat of the tank I shove the pump, it doesn't seem to mind.
Old Jun 8, 2002 | 12:00 PM
C5pilot's Avatar
C5pilot
I've never had that problem with my 98. However, I have discovered that I cannot fill the tanks completely if the car is not sitting level.
My guess would be there is an obstruction in your cars fill pipe. How it got there would be the obvious question.
Old Jun 8, 2002 | 12:24 PM
ROD BROWN's Avatar
ROD BROWN
I concur with one of the other replies.I would giess there is an obsrtruction in the gas filler pipe.You may want to take it to the agency to have the fuel system checked out.It is possible there has been a obstruction directly from the factory if you have had this problem since the car is new.I have a 99,and I have never had such a problem. :chevy :chevy :flag :chevy :chevy
Old Jun 10, 2002 | 01:59 AM
CoolYellowOne
Thanks for all the replies. I was thinking that there may be some kind of venting system that wasn't working correctly, and the pressure builds up during fillup. I guess I have to take it to the dealer. :confused:
Old Jun 10, 2002 | 01:49 PM
Mark S.'s Avatar
Mark S.
I've had this happen a couple of times...I just move over to another pump and then it seems to work fine. Sometimes it might just be an overly sensitive fuel nozzle that is giving a false signal to the pump to stop.
Old Jun 10, 2002 | 02:32 PM
IMQUIK's Avatar
IMQUIK
Don't stick it in so far :bb :bb :bb
I NEVER hear that! :lol: :lol: :lol:
Old Jun 10, 2002 | 03:31 PM
hpcubed's Avatar
hpcubed
Mine does it too, can't put it in so far.
Old Jun 10, 2002 | 03:59 PM
BlueVette2's Avatar
BlueVette2
St. Jude Donor '05
Default Re: Problems filling fuel tank! (hpcubed)
I have the same problem on my 02.. the 98 was great, never had an issue, but the new one is a pain in the butt...
sometimes it will take 5+ restarts to get the tank full.. :mad
Old Jun 10, 2002 | 05:12 PM
MDT's Avatar
MDT
I may be wrong here, but it seems to me that the tank should vent the pressure through the charcoal cannister. If the line to the cannister or the cannister itself is plugged, then the pressure would have to vent back past the filler nozzle.
Good luck.
Mark
Old Jun 10, 2002 | 05:30 PM
Lil Red's Avatar
Lil Red
I would be willing to bet that if you only put the nozzle in 1/2 to 2/3 the way into the fill pipe you won't have any problem at all. The fuel nozzle curves down tooooo much which causes the gas to splash excessively against the inside walls of the fill pipe just at the nozzle output. If you back it out about 1/3 the way I bet your problem will disappear. :cheers:
Let me know if this works for you!
Old Jun 10, 2002 | 09:10 PM
6SHIFTIN's Avatar
6SHIFTIN
My 2002 gives me the same filling trouble. I have tried adjusting the nozzle position as some have mentioned but it still seems hit & miss.
To Problems filling fuel tank!
