Rear seal leaking
Old Nov 23, 2012 | 03:58 PM
rookie60's Avatar
rookie60
Default Rear seal leaking
A mechanic told me my rear seal is leaking. How soon should I fix it if it is only leaking "slightly"? I don't notice anything on the garage floor. What is the average cost?
Old Nov 23, 2012 | 08:58 PM
fwrogg's Avatar
fwrogg
it probably will be fine for some time if you don't drive it real hard. Eventually you will get tired of the mess it makes around it as it will collect a lot of dust and stick to everything underneath, and fix it, probably before it drips a lot on the floor.
Old Nov 23, 2012 | 09:45 PM
DIXZ's Avatar
DIXZ
When you say "rear seal" do you mean the rear main seal on the engine or a seal on the differential?
To Rear seal leaking
