C5 Speedometer cluster
Old Nov 25, 2012 | 12:50 PM
lingenfelter200's Avatar
lingenfelter200
Default C5 Speedometer cluster
Hi,
I have a problem in my speedometer cluster. Everything is working fine oil pressure gauge, Eng temp, battery Vol, fuel limit and the RPM except the speedometer.
Any Idea?!
Old Nov 25, 2012 | 07:32 PM
DIXZ's Avatar
DIXZ
Has any work been done to the car lately? Is there a chance the VSS (Vehicle Speed Sensor) could be disconnected at the differential? Did the speedometer just quit working on it's own?
Old Nov 26, 2012 | 05:32 AM
lingenfelter200
When I connected my HPtuner scanner to my car to see if the scanner will read the speedometer or not?! it was working fine in the program. Do you think from the harness or the pin of the connector?
Old Nov 26, 2012 | 08:18 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
cluster gets info from the sensor on top of diff, verify it's plugged in as stated above
HP may get the info from the hubs, I don't have the info on that source
To C5 Speedometer cluster
