c5 headlights
Old Nov 26, 2012 | 06:41 PM
vetteriderr's Avatar
vetteriderr
Default c5 headlights
does anyone out there knows what the deal is when u turn the headlights on they come on and pop up . when u turn the headlights off lights go off but lights dont go back down they stay up but they will go down manually by hand . any thoughts thanks yall
Old Nov 26, 2012 | 07:10 PM
lionelhutz's Avatar
lionelhutz
Do you have HID's? If yes, try the high beams if you have halogen high beams or install resistors.
If no, try turning the ***** to lower them a bit and then turning off the lights. See if they close the rest of the way. If yes, my guess would be the gears are jambing enough the motors can't close the light. Odd both would do it but it's possible. If not, then it's likely the headlight module or the headlight switch.
Old Nov 26, 2012 | 09:43 PM
vetteriderr
nope there factory units
ill try that didnt think of it but ill try it . it thought of the module and headlight switch i took it off another car i have that i know works and nothing different even checked all the fuses . can u think of anything else thanks for ur input
To c5 headlights
