Oil Pressure problem
Old Nov 28, 2012 | 06:24 PM
Vettefan400's Avatar
Vettefan400
Default Oil Pressure problem
On my 2001 Vert The oil pressure is sky high. It used to run about 40 psi but now will not go below 129 psi. Do I have a bad oil sending unit or something worse?
Old Nov 28, 2012 | 06:32 PM
ZZOOM06's Avatar
ZZOOM06
Yes you do. That's what they do when they fail.
sliderhd's Avatar
sliderhd
Sounds like the sending unit. Does it go full scale when the key is turned on without start? That would be another indication. If you do a search you will find a lot of them have gone bad and also how to fix it several ways.
To Oil Pressure problem
