Attempted to remove my steering wheel
Old Nov 30, 2012 | 12:22 AM
Z06_N_SD's Avatar
Z06_N_SD
Default Attempted to remove my steering wheel
Talk about a royal pain. Horrible design. Why not just thread those holes like most cars. For those of you who dont know what im talking about, our cars(and a lot of GM) use 2 special J hooks that goes behind the steering wheel rather than two bolts that thread. I bought the kit from NAPA and both hooks broke. I am installing a MOMO jet steering wheel as I am tired of the bulky factory one. Yes, i will miss the airbag, but my seatbelt should do me fine until I put in some new seats/harnesses. Tomorrow i will attempt to return the steering wheel puller kit and get another one and try it again. Ill try to tap the hooks with a hammer this time to make sure they are seated all the way in with every turn. Other than this, does anyone have any tips? I've searched and searched but it seems as if its very common.
Old Nov 30, 2012 | 02:30 AM
Lothar34's Avatar
Lothar34
You can drill and tap holes and use a regular puller:
http://forums.corvetteforum.com/c5-t...el-puller.html
Old Nov 30, 2012 | 07:17 AM
WKMCD's Avatar
WKMCD
That's what we had to do. Good luck!
Old Nov 30, 2012 | 07:49 AM
Z06_N_SD's Avatar
Z06_N_SD
Thanks guys! Gonna give that a try.
Old Nov 30, 2012 | 08:20 AM
CactusCat's Avatar
CactusCat
Dude! You've got to change that nasty avatar !!
Old Nov 30, 2012 | 01:44 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
The reason is splines cannot loosen in the direction of wheel rotation. Even a lefthand thread would still be a technical problem. It is for your safety. Unfortunately, the splines don't let go in the perpendicular direction either.
Old Nov 30, 2012 | 01:57 PM
bmfvette's Avatar
bmfvette
WTF is up with that avatar....
Old Nov 30, 2012 | 04:37 PM
Z06_N_SD's Avatar
Z06_N_SD
Drum Roll: GOT IT! tapped out some holes(more than 2 due to wrong size), torqued the hell out of the puller-and whacked with a hammer. Finally came off. 'Twas no joke. Aluminum shavings everywhere, but nothing a vacuum cant fix. Ill post pics tonight/tomorrow morn. THANKS FOR THE IDEA GUYS.
Old Nov 30, 2012 | 06:11 PM
WKMCD's Avatar
WKMCD
That's the hot chick you're messaging on the interweb...
Old Dec 1, 2012 | 10:13 AM
bmfvette's Avatar
bmfvette
damn... I wish you hadn't said that...now I'm having this vision..
Old Dec 1, 2012 | 01:44 PM
Z06_N_SD's Avatar
Z06_N_SD
Default All done
Here it is....glad its all over with!
To Attempted to remove my steering wheel
