Build Update: Motor is Apart
Does anyone know if they do an acid dip for aluminum blocks? or if it's more of a dip in mineral spirits? Do you think it'd be possible to do this at home? I just sort of invision them dropping it into a tank of solution and it coming out super clean lol
But anyway, I've identified the actual failure - it seems the main bearings failed.
Enjoy some car p0rn.
(notice the oil sludge around the bolt .. yay lol)
I wanted to get some pics of the journals too ..
some of the toys ..
(here is a YouTube video of what it sounded it)
http://www.youtube.com/watch?v=MPXODzIBycU
If you feel the bearings, they are pitted and rough - they should be silky smooth to the touch.
To be honest, I'm happy to discover it was only the bearing as I thought originally I bent a rod. Also when I pulled the pan - there were almost no metal shavings in the bottom end.
I'm looking forward to getting the stroker into it and getting it back into the car
I'm not sure what is being used these days, depends on the environmental laws in your area and what the shop has.
Ron
Here are some of the rod bearings from I think Journel #4 (i'd have to dbl check)
Photo #1
Photo #2
Photo #3
In this gem you can see the bearing for journal #5 (i think) is fused to the crank. (I can't even pry it off)
Photo #4
Here is the one of journal 6 (this one is too is fused to the crank)
Photo #5
Photo #6
Photo #7
All in all, the block itself and the walls are in great shape (I was surprised since the motor has 220,000 miles on it). I had really been going back and forth on the stroker or swapping to the 402 LS2 but after checking out the block - I think I'm just going to keep it a LS1 motor based car.
I'll take some more pictures of the pistons and stuff just for fun and post 'em up later.
So next step - I've got a few more things to pull off the motor (pop the plugs, etc) and bring it right down to the base block - then give it a nice bath to get rid of any contaminants in the block.
I have a question for anybody who knows, I can't seem to find a definitive answer on it .. there are some metal scuffs on the top of the cylinder wall on cylinder #8 (just before where the wall actually begins, it's more in the main compartment area) - would it be okay to dremel this a bit and clean it up? I mean, I'll likely have to clearance the block anyway for the stroker but just wanted to through it up there for comments.
Cheers Guys.
I'm building it out as a forged 383.
will have some PRC 227's and a nice bump stick to match (23x/24x)
not exactly like your monster but I'm pretty confident it'll be enough to tootle around town.
How do you know when it's time to change the cam bearings?
yeh .. i'd say copper showing is a good sign.
just a few more pictures of prepping it ..
(pre-bath w/ tide and a scotchbrite pad)
(post)
still needs more TLC and a razoring of some of the surfaces. But at least now each time I touch it, it wouldn't leave me with a black greasy hand.
and a beauty shot
okay .. i'm done for now.
I forgot to take a picture of the side I was working on before I started so .. this is the other side .. they looked about the same haha
simple green + paint thinner + wire brush
taped and scuffed
first coat
I'll wait til that drys, scuff it again, and shoot it again. Thinking about maybe adding a clear coat (.. maybe not .. lets see how lazy I get
)oh and I took the engine cradle apart yesterday too .. oh boy was that thing diirrr-tay!
I had been told paint thinner and a stainless steel brush .. I tried it on one part of the engine the other day, it works pretty well but I'm hesitant until I see what happens to the metals to try it on the internal walls.
I've also been using scotchbritte pads and paint thinner, after I dunked the motor in tide.
