Engine Removal Help Needed
Old Jun 9, 2002 | 01:31 PM
Jason 98 TA's Avatar
Jason 98 TA
Premium Supporting Vendor
Default Engine Removal Help Needed
The main question is can you leave the car on its suspension without the motor in the car? I need it to still be mobile so we can pull the engine & then push the car out of the way until it gets back from the machine shop :)
Jason
Old Jun 9, 2002 | 01:36 PM
movinup's Avatar
movinup
Default Re: Engine Removal Help Needed (Jason 98 TA)
I believe the motor comes out from the bottom and
you have to drop the front suspension to do that. You
can put the suspension back together to do the roll-
around.
Old Jun 9, 2002 | 03:03 PM
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: Engine Removal Help Needed (movinup)
Take the engine out from the top and just wire up the transmission in place and the car will be movable :)
Old Jun 9, 2002 | 05:19 PM
C5Noir's Avatar
C5Noir
The engine can be removed from the top or bottom. Much easier from the bottom if you have a lift ;)
Old Jun 9, 2002 | 07:04 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In IV Veteran
So why is the motor going to the machine shop is the question? :yesnod:
Old Jun 9, 2002 | 07:55 PM
Jason 98 TA
Forged pistons just & tighter main bearings, just want the car to be mobile so we can push it out of the shop when we have other cars to work on :)
Jason
To Engine Removal Help Needed
