Will an EBCM rebuild solve my problem
Old Dec 8, 2012 | 09:04 PM
Erik_Hagglund's Avatar
Erik_Hagglund
Default Will an EBCM rebuild solve my problem
I'm getting the DTC C1272 code (LF TCS Valve Solenoid Malfunction) and according to the service manual, an EBCM change should fix the problem.
I've sent an email to CorvetteCentral.com to ask whether they think an EBCM computer rebuild would fix it, according to their webpage it will fix "Loss of communication with module, Loss of one or more wheel sensor inputs, Intermittent functionality and Water penetrations", but I don't know if a valve solenoid malfunction is covered in any of these...
I haven't received an answer from them yet (it's been two weeks) so I thought I'd ask the good, knowledgeable and helpful people on Corvette Forum if they have any input...
I need to fix it in order to have it approved in M.O.T
Any advice is highly appreciated
Old Dec 8, 2012 | 09:10 PM
Greg00Coupe's Avatar
Greg00Coupe
we need the year of the car. some can be rebuilt some not.
Old Dec 8, 2012 | 09:12 PM
Erik_Hagglund
Oh darnit, I thought I had put that in there.. it's a 2003, it says delphi on the unit. Sorry!
Old Dec 9, 2012 | 05:35 PM
m88vet's Avatar
m88vet
From: LA from the 6th sept till the 10th sept california ( then New Zealand)
hey ..try ABSFIXER. he will check it out and if he cannot fix it he wont charge you! i would say he can.. so you only pay shipping... then you can take it from there. new one is $500 bucks.....
Old Dec 11, 2012 | 04:51 PM
Erik_Hagglund
ABSfixer.. okay, will check it out... but before I do, do you think it'll be worthwile checking the grounds..? I guess that's the first thing I should do before starting tinkering... :P
Old Dec 11, 2012 | 05:00 PM
m88vet's Avatar
m88vet
yep check all 4 grounds up front of the car.. 2 by radiator , 1 under battery , 1 chassis rail to engine block. . dismantle clean, check , tighten. check connections F G on the ebcm plug with OHM meter to ground should be 0.00ohm. pin A 12v check?? Pin B 12v ignition on Check?
see how you go.
To Will an EBCM rebuild solve my problem
