Hurst shifter install ?
Old Dec 9, 2012 | 11:49 AM
bracketshark's Avatar
bracketshark
Default Hurst shifter install ?
I bought a used hurst shifter for the 99 FRC. Its bolted in and all of the gears feel fine. I went to install the rubber cover that takes the 4 nuts, and it doesn't come close to getting on without some trimming. Since I didn't get any paper work with this unit I'm hoping someone that has done this install will advise me what needs to happen. I don't want to cut this cover unless absolutely necessary. Thanks
Old Dec 9, 2012 | 01:02 PM
johnson-rod's Avatar
johnson-rod
You could cut the rubber gasket to fit (Horrors!) and install it normally.
OR
You have to flip it over and pull the rubber up through it backwards and install it upside down. Sounds weird but it does work. You can add a plumbers pipe block with a small hole (for the shifter shaft) over the rubber for a better seal.
I chose number 2 because sometimes I remove the Hurst and go back to stock.
Old Dec 9, 2012 | 01:46 PM
bumble-z's Avatar
bumble-z
Do Not Cut the Hard rubber , Tunnel Plate close out boot!!!
How ever the 2nd suggestion of reversing the close out boot & installing a rubber
I-1/4" or 1-1/2" PVC pipe end cap with a 5/8" hole drilled through the center of the rubber end cap, (for the shifter's shaft to slide through) would & does work great.
Old Dec 25, 2012 | 03:09 AM
zet06's Avatar
zet06
if U go back to stock or anyone else with a stock shifter,
I CUT 1 IN OF THE END OF THE SHAFT ( AFTER PUTTING A 9 /16 UNF NUT ON ) AND USE THE NUT AS A THREAD CHASER THEN PUT THE STOCK SHIFT **** ON AND THE **** SITS LOWER AND IS MORE COMFORTABLE, CUTTING ANY MORE SERVES NO PURPOSE AS THE **** WILL BOTTOM OUT ON THE BUMP IN THE BOTTOM PART OF THE SHAFT.
Old Dec 25, 2012 | 09:40 AM
bracketshark
Wow, OK???? I got the boot on without cutting it, just flipped it over as suggested. I didn't think that would work, but it fits like a glove. I've got the stock shifter (cheap) if you need one after cutting yours up.
To Hurst shifter install ?
