Help needed with PCM code
Old Jun 9, 2002 | 09:22 PM
C5Rated's Avatar
C5Rated
Default Help needed with PCM code
Got the car back Friday after having the 3.42 differential and the Yank 3000 installed. Have not gotten the powerloader back yet but needed to get the car back to my house from the shop (about 60 miles). Car seemed to be o.k. except for the 1st to 2nd shift which are pretty hard. Anyway, got about 5 miles from home and the check engine light came on but car was still running although a little rough at idle.
Pulled the codes and the one coming up for PCM is P1870 HC. This code is not listed in the IPC code list here on the tech tips so hoping someone here can tell me if this is a slip code or something else. Sucks waiting for the reprogrammed powerloader but supposedly should show up in the next week according to TTS. Just hate to wait if this code is saying something else related to the installation.
Thanks for the help all.
Old Jun 9, 2002 | 09:46 PM
C5Rated's Avatar
C5Rated
Default Re: Help needed with PCM code (C5Rated)
Sorry all. Just found the answer to this in another post. C'mon powerloader!!!!
