Raybestos Ceramic Brake Pads
Old Jun 10, 2002 | 12:35 PM
C5Noir's Avatar
C5Noir
Default Raybestos Ceramic Brake Pads
How much do these ruN? Thanks.
Old Jun 10, 2002 | 01:45 PM
BostonVette's Avatar
BostonVette
Default Re: Raybestos Ceramic Brake Pads (C5Noir)
I paid $79 for a set of fronts at Pep Boys.
I'm happy with them, no noise, no dust but...
I have a little problem with the adhesive backed shims that come them. The shims are installed on the outboard side and one of them has shifted and bunched up, looks like schit.
I've tried reapplying some adhesive, no dice.
Got a call into Raybestos, they are going to try to send another set of shims.
Be aware, clean the pads surface well before applying the shim.
Good luck :cheers:
Tom
Old Jun 10, 2002 | 02:28 PM
cgh1's Avatar
cgh1
Default Re: Raybestos Ceramic Brake Pads (BostonVette)
I have the same problem...
Have you tried running without the shims? Is it just too noisy? Of course, with mine gathererd like they are, they squeal anyway...
Old Jun 10, 2002 | 03:54 PM
MJM's Avatar
MJM
Default Re: Raybestos Ceramic Brake Pads (cgh1)
I'm running without the shims and have no noise.
Matt
To Raybestos Ceramic Brake Pads
