sway bars
Old Dec 17, 2012 | 03:41 PM
nmacdonald's Avatar
nmacdonald
Default sway bars
Quick questions, and please forgive my ignorance. My 99 has adjustable suspension - the real expensive kind to replace - is that called the Z51 suspension? I have three "ride" type options. I thought I would see an indicator in the glove box build info, but didn't see it or at least didn't recognize it.
Second, knowing I have an adjustable suspension, is my sway bar diameter the second on this list?
* C5 Base Suspension: 23 mm-front / 19.1 mm-rear / 3.81mm/2.0mm thickness
* C5 Z51 (97-99): 25.4 mm-front / 21.7 mm-rear
Old Dec 17, 2012 | 05:32 PM
SDVette's Avatar
SDVette
2025 C1 of the Year - Unmodified Finalist
2022 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
You (and I, on my 98) have the F45 adjustable suspension.
It uses the smaller (base) sway bars.
I have upgraded mine to the larger swaybars. It does make a noticeable improvement in keeping the car settled in corners with bumps.
Old Dec 17, 2012 | 05:55 PM
lionelhutz's Avatar
lionelhutz
You can get C6Z51 sway bars for around $200 and they would make a big improvement.
Old Dec 17, 2012 | 07:43 PM
nmacdonald's Avatar
nmacdonald
Thanks folks, I appreciate the reply and suggestions.
Old Dec 17, 2012 | 07:56 PM
newbs49's Avatar
newbs49
Sorry to ask another guestion. But would c6z06 bars be any better than the bars on a 01c5z06. Thanks for any help.
Old Dec 18, 2012 | 04:42 AM
tomlink's Avatar
tomlink
C6Z06 bars would give you more control but they are only recommended for use with a 335 rear tire. The C6Z51 bars are actually larger than the C5Z06 bars and work great on my C5 which originally came with the Z51 suspension. I'd stick with the C6Z51 bars unless I was able to stuff a 335 in the rear wheel well.
Old Dec 18, 2012 | 08:18 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The information below was taken from http://forums.corvetteforum.com/c5-g...house-com.html from GM Parts House.
Below are the specifications and comparisons of the C6 Z51 sway bars compared to other Corvette suspension packages.
Corvette Sway Bar Specifications
Suspension Front (mm) Rear(mm)
C5 base 23.0 19.1
C5Z51 (97-99) 25.4 21.7
C5Z51 (00-04) 28.6 23.6
C5Z06 30.0 23.6
C6 base 25.5 17.5
C6Z51 31.0 25.4
C6Z06 31.0 28.0
It doesn't state it, but I think the C6 Grand Sports use the C6 Z06 bars.
Old Dec 18, 2012 | 02:08 PM
newbs49's Avatar
newbs49
Thanks for the Info on the bars. I guess one should get both C6Z51 for a 01 C5Z06 even though you only pick up 1mm in the frt to balance out the package.
Thanks again for your thoughts on this.
Old Dec 18, 2012 | 07:58 PM
bighank's Avatar
bighank
Default Got mine in the parts for sale section check it out
If you find what you are looking for there will be a lot cheaper.
Old Dec 19, 2012 | 01:38 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Another way to add stiffness to your existing sway bars is to replace the RUBBER sway bar bushings with poly or urethane bushngs--Energy Suspensions claim that by doing this you add apprx 25% to the rate--
ALSO-- replacing the PLASTIC sway bar end links with the Z06 style METAL end links agains adds another 10-15 % to your rate----
Depends on your goals and your cars use---Remember that larger sway bars and stiffer rates will make the car drive very harsh during normal driving--When you drive over small bumps like road reflectors the car will tend to hop over the bumps raher than drive over them---On my 98 with metal end links and poly bushings and Stock sway bars seems be be a good compromise---But even still my car tends to "hop" over many bumps and its quite annoying--
PS: another way toimprove handing and car stiffness while corneringand also helps traction on hard launches is to replace the TRANS MOUNT with a solid design over the stock rubber piece---I got mine from VBP---
Old Dec 19, 2012 | 02:41 PM
SDVette's Avatar
SDVette
Do you have runflat tires?
I ditched the runflats for this very reason. The sidewalls are brutally firm, transferring every bump to the suspension.
For me the right compromise was the Z06 bars, bushings, and endlinks.. and NON RUNFLAT tires! (same setup used on the Z06)
Old Dec 21, 2012 | 03:04 PM
tblu92's Avatar
tblu92
No runflats---- Nitto 555's
Old Dec 22, 2012 | 11:43 AM
Mike98SilVert's Avatar
Mike98SilVert
If you plan to replace your F45 shocks with Z51 or Z06 shocks, here is what you need and some good DIY links:
http://www.westcoastcorvette.com/p-3...7-2004-c5.aspx
http://www.casperselectronics.com/st...90dfa3d23308a2
http://www.ls1howto.com/index.php?article=16
http://forums.corvetteforum.com/c5-t...my-99-frc.html
Old Dec 22, 2012 | 04:35 PM
C5Natie's Avatar
C5Natie
I have C6Z06 sways all around and they feel great. I track the car often and its flat as a pancake on the corners. I run a 315 tire in the rear.
Old Dec 23, 2012 | 12:51 PM
Jesse Asis's Avatar
Jesse Asis
Just picked up a set of C5 Z06 sway bars, purchased aluminum links and have the black poly bushings. I too have the F45 and was wondering the ride quality when I replace the stock sway bars with the Z06. If they are too harsh, I'll be switching back or swaping to the Z51 sway bars. I wanted to improve the ride and cornering ability not make it harsh and just doing the sway bars I thought would do that since I'm keeping the F45 shocks I have the selection on firmness.. I hope...
Old Dec 23, 2012 | 01:54 PM
jlaw1313@comcast.net's Avatar
Would upgrading sway bars affect Active Handling?
To sway bars
