Proper way to bleed clutch using a remote speed bleeder?
I got this from Auto Zone. Its a MightyVac hand pump.
Sure makes this job really easy and fast !
I hook it up to the bleeder valve.
Remove the cap on the reservoir.
Suck out the old fluid from the reservoir.
Clean the reservoir with a towel/cloth.
Pour in new fluid into the reservoir to full level marker.
Quarter turn the bleeder valve.
Pump-Pump-Pump-Pump-Pump-Pump the hand pump...
The pump will pull fluid thru the entire clutch assy.
The fluid starts to fill the clear cup, and the fluid goes down in the reservoir at the same time.
Keep a close eye on the reservoir and keep adding fluid as the fluid level drops.
Do not let the reservoir level get too low so air can get into the system.
I do this till I go thru a whole bottle of the below DOT4 fluid.(12 fl oz bottle)
Close the remote bleeder valve. Disconnect pump hardware.
Make sure your reservoir is at the FULL level when your done. (At the small lip inside reservoir).
Put cap back on reservoir.
DO NOT spill any fluid on your paint ! It will eat your paint.
Hope this helps !
Toque
http://www.walmart.com/ip/Mityvac-MV...r-Kit/17013400
Toque
I leave the end of the remote bleeder in a dish washing liquid bottle so I can examine it. There is always little pieces of crap in it even though the slave and master are new and have always been filled with GM clutch fluid. I'm amazed this system works at all.
I have a Mityvac. I just never considered it necessary in this application.
Hope this helps !
Toque
