Bill Curlee: Help with Starter Issues
Old Jan 1, 2013 | 01:12 PM
CamminC5's Avatar
CamminC5
St. Jude Donor '15-'16-'17-'18
Default Bill Curlee: Help with Starter Issues
EDIT:: Issue fixed:: The small terminal is broken inside the solenoid causing the intermittent issue::
I just installed a new motor in my car and the starter won't spin. I used a meter to verify 12v ground on the case, then check for singal input to spin the starter from the purple wire and it's not there.
The security light isn't blinking, and all fuses are good (checked with a meter).
The block was painted, but I sanded all surfaces where the grounds connect the block, and had a buddy verify they were all hooked up when we installed the engine. I disconnected the purple wire and jumpered that lug to the 12V+ lug to ensure the solenoid is good.
I'm stumped....
Old Jan 1, 2013 | 04:52 PM
CamminC5's Avatar
CamminC5
Just verified the yellow wire from the column triggers + when key goes to start car, and verified the clutch switch is good.
I don't know what else to do...
Old Jan 1, 2013 | 05:08 PM
CamminC5's Avatar
CamminC5
No Codes on the DTC
Old Jan 1, 2013 | 06:55 PM
CamminC5's Avatar
CamminC5
Verified the Theft Deterrent Relay is operable. On "key to start" purple wire shows +. So its between that relay and the starter.
Old Jan 2, 2013 | 03:50 PM
Banditz's Avatar
Banditz
Glad you got her fixed. Seems like you narrowed her down in the correct order all by yourself! Great job!!
To Bill Curlee: Help with Starter Issues
