Donaldson Blackwing Install Question
Old Jun 11, 2002 | 01:58 PM
chwhale's Avatar
chwhale
Default Donaldson Blackwing Install Question
Corvette forum members,
I've got an order in for the Donaldson Blackwing for my 1999 coupe. I'm by no means a mechanic, and was curious if the install was difficult? Is the instructions for the install good? Are there any tips for making the install go smooth? I'd appreciate any help.
Thanks!
:confused:
Old Jun 11, 2002 | 02:04 PM
OhNiner's Avatar
OhNiner
Default Re: Donaldson Blackwing Install Question (chwhale)
Just don't break the little clip on the plug. It is a simple swap, I did it myself.
Old Jun 11, 2002 | 02:10 PM
pburant's Avatar
pburant
It helps to have a little silicone lubricant on hand for the four rubber grommets you'll have to deal with (two on the snorkel, two on the airbox). Not a requirement, but helpful....
Old Jun 11, 2002 | 03:20 PM
SoCal C5's Avatar
SoCal C5
It is an easy straight forward installation.
Old Jun 11, 2002 | 05:04 PM
Dale RED 98's Avatar
Dale RED 98
Default Re: Donaldson Blackwing Install Question (SoCal C5)
You will be fine. Straight foward instructions. Just take your time and it will work out. :D :cheers:
Old Jun 11, 2002 | 06:47 PM
kraff's Avatar
kraff
I have a word document with pictures of the install and instructions if you want it I'd be glad to email it to you. Made it a breeze for me. The file is a bit large however, just drop me a note if you want it.
Old Jun 11, 2002 | 10:56 PM
VetteDawg's Avatar
VetteDawg
Anyone can do it. All I needed was a screwdriver and a little lube.
Don't be afraid to apply a little muscle in getting the old box off of the nose of the car. Save the rubber grommets.
Some of us never got the Blackwing to seat properly into the tabs of the radiator shroud but it doesn't seem to matter if it seats there or not.
It's actually a fairly enjoyable task I thought.
Aside from driving it, what's better than playing with it? :)
Old Jun 12, 2002 | 12:20 AM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Default Re: Donaldson Blackwing Install Question (Aln)
I even pulled the tabs on the top of the radiator cover off, so I would not have to worry about it. :crazy: It should take you 5 to 15 minutes...tops. Your beer won't even have a chance to get warm before you're done. :lol: :cheers:
[Modified by RedHot, 11:21 PM 6/11/2002]
Old Jun 12, 2002 | 02:03 PM
chwhale's Avatar
chwhale
Thanks for all of your advice so far. I have another question to go along with my first one. Isn't there some kind of "re-learning" that the engine has to do after you install the air intake? How difficult is it to do, or do you even have to do it? Thanks!
Old Jun 12, 2002 | 04:34 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
There is a relearning process that you can do, but it is not necessary. The car itself is constantly relearning, so just by driving, it will be relearning.
Old Jun 12, 2002 | 05:40 PM
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Thanks!
:confused:
Chris,
Sent you some info as well as the tracking number. Enjoy!:)
RG
Old Jun 12, 2002 | 07:23 PM
HOCKEY's Avatar
HOCKEY
Default Re: Donaldson Blackwing Install Question (RG in Dallas)
Took me 20 minutes and no relearn, just drove it. Have fun.
Old Jun 12, 2002 | 07:50 PM
MP_Scillieri's Avatar
MP_Scillieri
Cruising
Do you need to worry about water/rain with the Blackwing? :flag
Old Jun 12, 2002 | 08:16 PM
RedHot's Avatar
RedHot
CI 5-6-7-8-9-10 Vet
Default Re: Donaldson Blackwing Install Question (MP_Scillieri)
If you got the hood seal then no, otherwise...no. :D
To Donaldson Blackwing Install Question
