Transmission problem... first gear pops out occasionally...
Old Jun 11, 2002 | 07:55 PM
WannaBe TT!'s Avatar
WannaBe TT!
Default Transmission problem... first gear pops out occasionally...
Well, i just recently purchased my vette and i find that sometimes when i push it into 1st gear it doesn't go in all the way, but the shifter stops as if it had, and then when i begin to let the clutch out it pops out of gear pretty aggressively. This never happens when i'm actually in gear, just when i'm trying to engage first. I'm curious what you all think the problem is or if it's just me?! Usually when i push it in, it goes in smooth all the way, but others it stops short.... do u think an aftermarket shifter could fix this, or is there something wrong with the transmission, or is it just me?! Thanks.
Old Jun 11, 2002 | 08:06 PM
TooManyIDs's Avatar
TooManyIDs
Default Re: Transmission problem... first gear pops out occasionally... (WannaBe TT!)
If I recall, there was a post about first gear having three synchro's? Maybe you aren't engaging far enough?
A shifter might help, since the throw would be reduced.
Old Jun 11, 2002 | 08:10 PM
NassyVette's Avatar
NassyVette
Default Re: Transmission problem... first gear pops out occasionally... (TooManyIDs)
An aftermarket shifter will help alot in reducing this problem. Its common.
Old Jun 11, 2002 | 08:53 PM
JHS5YDO's Avatar
JHS5YDO
My 99 FRC did this when it was new. I think its partly because every thing was new & stiff. Also I dont think I was pushing the clutch all the way in; I moved the seat up a notch or two and that helped alot (easier to get the clutch all the way in). I also changed to to Mobil 1 ATF in the transmission. I now have 15K miles on it and it never does it any more. I think its mostly getting used to the car. :cheers:
Old Jun 11, 2002 | 11:33 PM
WannaBe TT!
Default Re: Transmission problem... first gear pops out occasionally... (JHS5YDO)
Thanks guys... i was looking into an aftermarket shifter anyways... the throw is too long for my tastes. What do you all recommend?
Old Jun 11, 2002 | 11:43 PM
pjazz's Avatar
pjazz
C6 of Year Winner (performance mods) 2019
I have a ripper shifter and it still happens occasionally.
Old Jun 12, 2002 | 12:17 AM
borba's Avatar
borba
Default Re: Transmission problem... first gear pops out occasionally... (pjazz)
Hurst if you can find one! :crazy:
Old Jun 12, 2002 | 12:38 AM
sunvet's Avatar
sunvet
This has always happened to me occasionally, I've just learned to make sure to push hard going into first. Sometimes I have to let the clutch out to spin the trans, then try again.
You might want to try modifying the stock shifter. The shift distance is less, and the shifter height is nice and low. :smash:
There have been previous posts about modifying the stock shifter.
Old Jun 12, 2002 | 03:37 AM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
Default Re: Transmission problem... first gear pops out occasionally... (sunvet)
At around a couple thousand miles mine popped out of 1st, 3rd, and 5th. The dealer fixed it and then the synchros went out a few thousand later. Since then, no problems except while getting used to the new Hurst.
Old Jun 12, 2002 | 04:13 AM
teeceemv's Avatar
teeceemv
Mine does that too. I think it's in, and when I let the clutch out it pops out with an awfully loud noise. Embarrasing as hell. Now I jam it good and hard into first every time.
[Modified by teeceemv, 12:15 AM 6/12/2002]
To Transmission problem... first gear pops out occasionally...
