January 2013 C5 Specials - www.PartsTaxi.com
Former Vendor
January 2013
Please remember, we may not always be on the forum to answer all questions as often as we would like. To contact us, please email kevin@partstaxi.com, amelson@partstaxi.com or parts@partstaxi.com, lastly, you can call us at 302-883-0227.
Helms Service Manuals - $184.95
Currently available 07-04 Helms Service Manual Sets. To order, please use part number C5HELMS under the Chevrolet make. Please note in the comment section of the order what year manual set you are ordering.
1997-2000 Key Fob (Transmitter) - 19299230 - IN STOCK - $79.88
------------Maintenance & Common Replacement Parts-------------
C5 Maintenance Parts
25329389 - UPF44 Oil Filter - $8.99 each
19210283 - PF46 Oil Filter - $4.78 each
25042562 - 1997-2004 Air Filter - $12.58
10287788 - 1997 & 1998 Fuel Filter - $13.96
19239926 - 1999-2004 Fuel Filter & Pressure Regulator - $78.06
12621258 - Iridium Spark Plug - $5.49 each
12495519 - GM Performance Parts Red 8mm Spark Plug Wire Set - $54.39
12572188 - Serpentine Belt - $50.18
19172680 - A/C Compressor Belt - $50.61
12560345 - All C5 A/C Belt Tensioner - $81.75
12557334 - All C5 A/C Belt Idler Pulley - $38.26
12559325 - 97-00 Serpentine Belt Tensioner - $80.15
12568181 - 01-04 Serpentine Belt Tensioner - $71.39
12564401 - All C5 Serpentine Belt Idler Pulley - $49.59
GM Keyless Entry Transmitters/FOBS
19299230 - For 1997 - 2000 - $79.88
25695954 - For 2001 - 2004 #1 - $59.65
25695955 - For 2001 - 2004 #2 - $59.65
C5 Tire Pressure Sensors
25773946 - 2001 - 2004 Sensor - $39.98 each
25981210 - 1997 - 2000 Sensor - $99.78 each
15234846 - 1997 - 2004 Nut - $3.89 each
--------------Suspension Upgrades/Replacement Parts---------------
20822934 - Upgraded Metal End Links - $23.97
GM Has now updated all C5 & C6 to the metal end links. These are a direct replacement. These all metal end links are an easy replacement and will solve the common "clunk" noise
C6 Z51 Front and Rear Sway Bar Kit
Our most popular bar kit. Kit includes front and rear stabilizer bars and bushings for Z51. We are now proud to offer our customers the choice of either the OEM GM bushings or the poly Pfadt bushings for the same price! - $199.97
C6 Z51 Sway bar kit will work on C5 with no modification needed
C6 Z06 Front and Rear Sway Bar Kit
Kit includes Front and Rear Stabilizer Bars for C6 Z06 and insulators - $231.98
C6 Z06 Sway bar kit will work on C5 with no modification needed
C6 Z06 kit is not recommended for use with rear tire sizes under 315. Any smaller then a 315 tire, these will cause the rear to wash out.
2013 C6 Z06 Shocks
10313647 - Front Shock - $62.88 each
25819268 - Rear Shock - $61.75 each
All 4 Shocks for $249.24
C6 Z06 shocks will work on C5 with no modification needed
2004 C5 Z06 Shocks
10339944 - Front - $115.06 each
10339945 - Rear - $139.61 each
Complete set for $509.34
T1 SACHS Shocks
Front - 12480094 - $169.88 each
Rear - 12480095 - $169.88 each
That's $679.52for all 4 + $36 shipping
T1 Springs
12480063 - Front Spring - $878.44 + $24 shipping
12480064 - Rear Spring - $878.44 +24 Shipping
T1 Sway Bar Kit
T1 Sway Bar Kit consists of F&R T1 Bars and bushings - $559.99 + $3- shipping
Add Fully adjustable T1 End Links for $219
Or
Add C6 Metal End Links for $91.12
Hotchkis Suspension
Hotchkis Sport Suspension C5 Sway Bar Kit - 2285 - $359.95
Bilstein
B6 Heavy Duty C5 Front Shock - 24-029759 - $87.99 each
B6 Heavy Duty C5 Rear Shock - 24-029766 - $87.99 each
B8 Sport C5 Front Shock - 24-029773 - $87.99 each
B8 Sport C5 Rear Shock - 24-029780 - $87.99 each
Koni
Koni FSD Series Non Adjustable Shocks (set of 4) C5 - 2100-4053 - $759.95
Koni Sport Adjustable Shocks Front C5 (pair) - 3013-1023Sport - $679.99
Koni Sport Adjustable Shocks Rear C5 (pair) - 3013-1024Sport - $679.99
QA1
QA1 Front Shock C5 Non Adjustable - TN510 - $85.95 each
QA1 Rear Shock C5 Non Adjustable - TN705 - $85.95 each
QA1 Front Shock C5 Single Adjustable - TS510 - $165.99 each
QA1 Rear Shock C5 Single Adjustable - TS705 - $176.99 each
QA1 Front Shock C5 Double Adjustable - TD510 - $259.95 each
QA1 Rear Shock C5 Double Adjustable - TD705 - $279.95 each
QA1 Corvette "R" Series Front Shock Adjustable - TR510 - $179.95 each
QA1 Corvette C5 Single Adjustable Pro Coil Over Front System - GS402-09550 - $499.99
QA1 Corvette C5 Single Adjustable Pro Coil Over Rear System - GS403-07550 - $579.99
QA1 Corvette C5 Double Adjustable Pro Coil Over Front System - GD402-09550 - $678.99
QA1 Corvette C5 Double Adjustable Pro Coil Over Rear System - GD403-07550 - $769.99
QA1 Corvette C5 Drag Race "R" Series Pro Front Coil Over System - GR402-9550 - $535.99
----------------Brake Upgrades/Replacement Parts------------------
1997 - 2004 C5 Hawk Pads
Performance Ceramic Front - HB247Z575 - $98.58
Performance Ceramic Rear - HB248Z650 - $63.57
HPS Front - HB247F575 - $94.14
HPS Rear - HB248F650 - $63.85
HP Plus Autocross Front - HB247N575 - $99.84
HP Plus Autocross Rear - HB248N650 - $79.44
We do offer the entire Hawk catalog of brake pads, we just don't have them on our website yet. If you are looking for pads for a different vehicle, please email kevin@partstaxi.com or call us and we will get you taken care of.
GM C5 Ceramic Brake Pads
88909667 - Front Ceramic Pad Kit - $69.98
88909668 - Rear Ceramic Pad Kit - $48.85
C5 OEM Brake Pads
19181427 - Front Pad Kit - $139.77
12530688 - Rear Pad Kit - $63.75
OEM Brake Rotors
10445856 - Right Front - $51.95
10445857 - Left Front - $51.95
10445858 - Right Rear - $51.95
10445859 - Left Rear - $51.95
That's only $207.80 for all 4!!!!
Z06 Brake Calipers (Red)
Left Front - 88895128 - $125
Right Front - 88895129 - $125
Left Rear - 88895130 - $89.95
Right Rear - 88895131 - $89.95
You can order individually by part numbers listed above, or;
ORDER COMPLETE SET HERE - $429.90
C6 Z06 Brake Upgrade Kit
Kit includes both front calipers, both rear calipers, both front rotors, both rear rotors, front and rear GM OEM pads. We prefer not to substitute ACDelco as a replacement on this kit. Will need appropriate wheels for clearance and aftermarket stainless steel lines- $1899.99
C5 Z06 Brake Ducts & Screens/Scoops
Screens/Scoops
Left Front Screen/Grille- 10424821 - $112.87
Right Front Screen/Grille- 10424820 - $112.87
$197.76 For the front pair
Left Rear Scoop/Screen - 10322761 - $87.67
Right Rear Scoop/Screen- 10322762 - $87.67
$159.96 for the rear pair
Brake Ducts
Left Front - 10295976 - $29.78
Right Front - 10295977 - $29.78
$55.90 for the front pair
Left Rear - 10425976 - $32.40
Right Rear - 10425977 - $32.40
$55 for the rear pair
2012 C6 Shifter
25823572 - Shifter - $125.41
25821873 - **** - $64.78
11609670 - Bolt - $2.72
Total Kit $192.91
This kit works on all C5's but you will need to modify your boot during installation to fit. Or, of course you could purchase an aftermarket boot.
Genuine OEM GM C6 LS7 Clutch Kit
LS7 Clutch Kit - Kit includes LS7 Clutch and Flywheel - $429.48
LS6 Slave Cylinder - 89059282 - $129.85
LS6 Master Cylinder - 12564455 - $139.78
Pilot Bearing - 14061685 - $12.98
LS7 Clutch works with all C5 drive train but must utilize LS7 flywheel provided in kit.
Must use LS6 hydraulics in C5. LS7 hydraulics will not work in C5.
LS7 Clutch Kit with Aluminum Ram Flywheel and ARP Flywheel Bolts - $579.80
---------------Interior Upgrades/Replacement Parts----------
Genuine GM Replacement Sport Seat Pads/Foams
2001-2004
10273418 - Driver & Passenger Seat Back Outer - $46.45 each
10283891 - Driver & Passenger Seat Back Insert - $96.46 each
10273420 - Driver Seat Cushion Pad - $118.08
88991516 - Passenger Seat Cushion Pad - $69.82
1997-2000
10273420 - Driver & Passenger Seat Cushion Pad - $118.08 each
GM Ebony Radio Surround Bezel - 10407815 - $224.88
GM Corvette Emblems
2003 50th Anniversary Front Bumper Emblem - 19207387 - $82.05
2003 50th Anniversary Rear Bumper Emblem - 19207386 - $82.76
2003 50th Anniversary Front Fender Emblem - 10315690 - $140.89
Z06 Front Fender Emblem - 10429629 - $46.46
Z05 405HP Front Fender Emblem - 10314089 - $42.92
2004 Front Bumper Emblem (CE) - 19207388 - $151.92
2004 Rear Bumper Emblem (CE) - 19207389 - $111.10
GM Lower Radiator Cage/Support
Radiator Cage/Support - 10400765 - $318.64
You will need the threaded insets listed below to install the new cage. I have also listed the bolts if you need new bolts
Nut Insert - 11609836 - $2.84 need 1
Nut Insert - 11518908 - $4.53 need 7
Bolt - 11570082 - $.88 need 1
Bolt - 11514623 - $.95 need7
GM C5 Ignition Switch Bezel - 2852046 - $14.81
GM C5 Door Panel Pull Plug - 10279471 - $2.43
--------------------Engine/Mechanical Parts---------------------
GM Cylinder Head Bolts and Gaskets
LS1/LS2/LS6 Round Port Header Gaskets - 12617944 - $11.76 each
97-01 LS1 Head Gaskets (Pair of 2) - 12498543 - $43.70
02-04 LS1/LS6 Head Gaskets (Pair of 2) - 12498544 - $31.05
97-12/03 LS1/LS6 Head Bolts - 12498545 - $23 per head
1/2004 and newer LS1/LS2/LS6 Head Bolts - 17800568 - $23 per head
LS2 Head Gasket - 12589227 - $36.98 each
GM LS2 Items
LS2 Bare Block - 12602691 - $1099.98
LS2 Throttle Body - 12570790 - $425
LS2 Fuel Rail - 12633511 - $155.94
LS Stock Replacement Lifter Set (16 lifters) - 12499225 - $119.99
LS6 "Bee Hive" Valve Spring Set - 12499224 - $55.38
OEM GM Intake Manifold
Intake Manifold - 88894339 - $484.16
Coolant Pipe - 12602544 - $36.34
Coolant Plug (need 2) - 12602540 - $6.79 each
Total only $545.61!! Shipping on these 3 items anywhere in the continental US will be anywhere from $15-$22.
BBK LS1 LS6 Intake Manifold C5 Corvette - $698.99
FAST LSXR 102mm Intake Manifold LS1 LS2 & LS6 - $879
Vararam Ram Air Intake - VR-B2 - $239
----------------------GM Performance Parts----------------------
We are a GM Performance Parts Dealer. This is only a very small portion of the performance parts we offer. If you don't see what you are looking for, please email me at kevin@partstaxi.com. You can click on the description to go directly to the part on our website for more information.
Bare Engine Blocks
Aluminum C5R Racing Engine Block - 12480030 - $6997.75
LS7 Engine Block - 19213580 - $2685
LSX Tall Deck Engine Block - 19244059 - $2258
LSX Bowtie Engine Block - 19213964 - $2039
LS2 Engine Block - 12602691 - $1099.98
LS1/LS6 Engine Block - 12561166 - $979.88
GMPP Cylinder Heads
All Cylinder Heads are priced as each
CNC Porter LS6 Race Cylinder Head - 88958622 - $1099 each
LSX-L92 Small Bore Cylinder Head - 19201807 - $789.88 each
LSX-LS3 Cylinder Head - 19201805 - $919.88 each
LSX-CT (Circle Track) Cylinder Head - 19166981 - $1690.88 each
LSX-DR (Drag Race) Cylinder Head - 19166979 - $1690.88 each
LSX 4.125 Stroke Crank Shaft - 19244018 - $1220
24x Reluctor Wheel for 97-04 - 12559353 - $15.75
58x Reluctor Wheel for 05 & Newer - 12586768 - $16.88
LSX 6.000 Connecting Rod Set - 19166964 - $458.90
GM Performance Parts Cams - Please click on the links to view exact cam specs.
Hot Cam Kit - comes with Hot Cam, 16 LS6 Valve Springs and Retainers - $468
GM Performance Hot Cam - 88958733 - $399.71
GM Performance LS Stage 2 Cam - 88958722 - $399.71
GM Performance LS Stage 3 Cam - 88958723 - $399.71
LSX 454 Cam - 19166972 - $289
Valve Train
Racing Hydraulic Roller Lifter Kit - 88958689 - $249
LS High Volume Oil Pump (LS1/LS2/LS6) - 17801830 - $75.30
2013 C6 Z06 Shocks
2004 C5 Z06 Shocks
T1 SACHS Shocks
T1 Springs
T1 Sway Bar Kit
Or
Hotchkis Suspension
Bilstein
Koni
QA1
C5 OEM Brake Pads
OEM Brake Rotors
Screens/Scoops
Brake Ducts
2012 C6 Shifter
Total Kit $192.91
2001-2004
1997-2000
GM Corvette Emblems
GM LS2 Items
Bare Engine Blocks
GMPP Cylinder Heads
Valve Train
