Alternator maybe?
Old Jan 21, 2013 | 09:57 PM
Choreo's Avatar
Choreo
Default Alternator maybe?
2001 LS1 55,000 miles (about 30,000 miles on this alternator - GM Valeo Replacement under warranty a few years ago).
I just finished my workout at the gym, got in the car, started the engine and heard a low-pitched "roar". Looked down and the Voltmeter/DIC had dropped to 11.7. At first I thought maybe I had thrown a belt, but it was OK.
I opened the hood and could not tell where the roar was coming from, but there was a smell something like burning rubber or plastic I think - no smoke. I made it down the street to the local O'Reillys and they could not tell where the roar was coming from either. They hooked up their analyzer and it read 12.1 (which they said was low).
Battery is only 4 months old Die Hard P4 Platinum and it reads 14.63V - so I think it is fine.
Made it home about 2 miles with the Voltage gage reading about 11.7 all the way (usually is just under 14 and I watch it like a hawk every time I get in the car).
So, any ideas what my problem is? Think I need a new alternator or could this be something else dragging the voltage down that "roars"?
Old Jan 21, 2013 | 10:08 PM
NukeC5's Avatar
NukeC5
Did this "roar" continue after the drive? The only thing I know of that makes a louder noise when you start up and stays on till operating temp is the air injection system. But that doesn't sound like your issue... Shouldn't have anything to do with volts anyway...
Old Jan 21, 2013 | 10:10 PM
robert miller's Avatar
robert miller
Check your pulley the roar could be it has got bad.. Robert
Old Jan 21, 2013 | 10:14 PM
Choreo's Avatar
Choreo
Are you referring to the Idler pulley?
The sound was similar to the sound when you are out of Power Steering fluid and try to turn the wheel, but it checked out to be full when I got home and no steering issues on the way home. Not sure how the steering would affect voltage either unless maybe the power steering pump was somehow seizing up?
I understand the Alternator on the Automatic (like mine) has a Clutch Pulley. Could that be it? Can it even be changed?
Old Jan 21, 2013 | 11:32 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
More than likely, thats your problem... the clutch is slipping... its there to stop belt chirp when going into gear... if the clutch is slipping it will effect your voltage output. if you could smell rubber, thats where i would look first...
Old Jan 22, 2013 | 12:06 AM
Choreo's Avatar
Choreo
I will tear into it tomorrow. That seems a logical starting place to me as well.
The roar is louder at idle than when the car is going down the road or accelerating. But the voltage at the gage never improves regardless of speed. Whatever it is, started suddenly without any previous symptoms. Drove a couple miles to the gym and no voltage or roar. Came out 1 hour later, started the car and there it was?
I am not seeing where anyone sells just a replacement clutch?
Old Jan 22, 2013 | 02:41 AM
Choreo's Avatar
Choreo
Could not sleep, so I went ahead and tore into this project tonight...
From what I can tell, with the serpentine belt removed, all the pulleys and idlers except the alternator clutch/pulley appear to be silent if I spin them by hand. When I spin the clutch/pulley on the alternator and stop it with my fingers, it make kind of a raspy sound? I guess that could develop into a "roar" under load a running speed?
I have no frame of reference since i never played with it when it was new to see if it made any sound.
If that is the cause, then since I cannot find any clutch replacements, guess I am looking at a new Alternator again. I see a couple options maybe...
• I see this remanufactured one at O'Reilly with a Lifetime Warranty that says it replaces my Valeo Part Number 10316182 - $169 + $30 core w/FREE Shipping 24 hour delivery
http://www.oreillyauto.com/site/c/de...ord=alternator
Looking online is see a lot of bad reviews on Ultima Alternators - so I guess that is out.
• New OEM from Forum Vendors looks like about $425-$455 + a ton of shipping
This is my only car (DD) - so I need to get something swapped out ASAP.
My alternator...
Old Jan 22, 2013 | 06:57 AM
Evil-Twin's Avatar
Evil-Twin
IN this case ( DD )... I would get anything that has a lifetime warranty.
Rather than an online vendor... dont you have a local Advanced auto, Auto Zone, or Pep Boys??? to swap out the alternator only takes 15 minutes... a lifetime warranty will insure you wont have to pay for another alternator... make sure you keep the receipt somewhere safe, in the event you have a problem.
Good Luck
Bill aka ET
Old Jan 22, 2013 | 11:48 AM
corvettebob1's Avatar
corvettebob1
Goodyear sells replacment decoupler PN/49908
Old Jan 23, 2013 | 04:10 PM
Choreo's Avatar
Choreo
OK... I bit the bullet and installed the Ultima Re-Manufactured Alternator from O'Reilly today.
• The 'roar" went away - so I am guessing it was the clutch/decoupler as we suspected that was causing the sound.
• My voltage on the dash gauge AND the DIC now read 14.3V steady. This is the first time since I have owned the car that I have seen the fabled 14+ Volts! Both my factory Valeo alternators never got me above 13.7 on their best day. I am showing 15.1 Volts at the battery with the car running.
So, I guess this means it WAS the alternator that crapped out - the question is, are these new voltage readings I am getting in the safe zone?
Old Feb 18, 2013 | 12:21 PM
tacman's Avatar
tacman
St. Jude Donor '13
Good Luck
Bill aka ET
...Also keep the box! Some vendors require return in the original packaging. I'm going to have to eat $225 because I no longer have the original packaging for the wrong part (my mistake). Large on-line vendor selling GM-only parts.
Old Feb 18, 2013 | 02:55 PM
Evil-Twin's Avatar
Evil-Twin
If I buy anything for my car.. I take a picture of the old part, a picture of the new part, and a picture of the box with the part number, and a picture of the receipt.. I put it in a folder on my computer that says Corvette.. inside that folder I have sub folders like, starter replacement 2011. or water pump replacement 2006... in that way I have documentation. Having a receipt that is 8 years old could very easily be deteriorated to the point that you cant read it.. a copy of that receipt on your computer with be as clear as the day you scanned it. I also have a Book with every receipt for every maintenance item oil and filter receipt, every mod, upgrade, tune, test, inspection, etc.
To Alternator maybe?
