Vibration C5
Old Jan 21, 2013 | 10:23 PM
Shoeman's Avatar
Shoeman
3rd Gear
Default Vibration C5
feel vibration in steering wheel and in seat between 50-80mph. automatic transmition. just had wheels balanced. no curbs hit.
Old Jan 21, 2013 | 10:28 PM
jerrypc's Avatar
jerrypc
I've seen this with a bent rim and degradation with the steel belts in tires.
Old Jan 21, 2013 | 10:56 PM
NukeC5's Avatar
NukeC5
Was this not the case before the balance? If this is new after the balance, they did it wrong and you need to return it to them to do it again.
Old Jan 22, 2013 | 12:33 AM
striper's Avatar
striper
When balancing wheels, if you feel it in the steering wheel it is bad front balance. If you feel it in the seat, the problem is in the rear. Must be that all four wheels need to be rebalanced. If that is the case, I'd have either someone else at that shop re-do it or go somewhere else.
To Vibration C5
