POWER CONTROL MODULE?
Old Jun 13, 2002 | 06:35 AM
JUICEMAN929's Avatar
JUICEMAN929
Default POWER CONTROL MODULE?
has anybody used this mod? and what were the results?
i found this item in ecklers for $ 250.00.
suppose to plug in this power module and your engine's fuel and ignition curves are instantly modified. increasing both torque and horsepower through the engine's entire rpm band, resulting in faster acceleration of wide open throttle and enhanced part throttle drivability. :rolleyes:
:cheers:
[Modified by JUICEMAN929, 12:28 AM 6/14/2002]
Old Jun 13, 2002 | 04:43 PM
90 droptop's Avatar
90 droptop
Default Re: POWER CONTROL MODULE? (JUICEMAN929)
Please describe your question. Your PCM is used to in the function of your engine.
Old Jun 13, 2002 | 08:30 PM
JUICEMAN929
Default Re: POWER CONTROL MODULE? (90 droptop)
sorry bout that drop top :crazy:
i should of more explained :rolleyes:
:cheers: thanks
Old Jun 21, 2002 | 03:35 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
I was just looking at the same piece. It looks like it hard wires into the car somehow (I know very little about the inner workings of the PCM). I'd also like to know the pro/cons of installing this :confused:
It is item #41877 in the Summer/Spring Ecklers catalog if that helps to describe it.
[Modified by BQuicksilver, 2:36 AM 6/21/2002]
Old Jun 24, 2002 | 05:25 PM
BQuicksilver
Default Re: POWER CONTROL MODULE? (BQuicksilver)
TTT
To POWER CONTROL MODULE?
