HELP!!! CAR CUT OFF ON ME!!!
Old Jun 13, 2002 | 10:31 AM
Snafu's Avatar
Snafu
Default HELP!!! CAR CUT OFF ON ME!!!
Anybody know anything about this?...I'm driving around a curve where there is a stop sign up ahead, so take it out of gear and coast up to the stop sign. As I'm taking the turn, the steering wheel locks up on me and it gets real hard to steer, luckily it wasn't a sharp turn and I rolled up to the stop sign. As soon as I stopped the car just shut off. I reached down and cranked her back up and she ran fine...ANY THOUGHTS :confused:
I'm afraid it'll happen again and the turn will be more sharp.
Old Jun 13, 2002 | 01:36 PM
numtin's Avatar
numtin
Default Re: HELP!!! CAR CUT OFF ON ME!!! (TakeAll8)
actually i had this happen to me last week, coming around a slight turn at 120mph. It scared the hell out of me, when the steering got tight so quickly, i tried to rev it and notice the car died, so i started it, and slowed down. everything has been fine since, but its still in the back of my mind.
Old Jun 13, 2002 | 01:43 PM
77-4speed's Avatar
77-4speed
Default Re: HELP!!! CAR CUT OFF ON ME!!! (numtin)
You need the column lock bypass. Do a search on this forum as there are a ton of answers.
Old Jun 13, 2002 | 02:20 PM
MaxPower's Avatar
MaxPower
Had the exact same thing happen to me last week. I did not know what the hell happened. One minute driving down the road the next minute the car is off. No stutter nothing. I put the car in neutral started right back up and everything has been fine since. Really weird. I am thinking it might be aliens, but I have been unable to confirm. :eek: oh btw I have the column lock bypass
[Modified by MaxPower, 12:21 PM 6/13/2002]
Old Jun 13, 2002 | 03:03 PM
Snafu's Avatar
Snafu
Default Re: HELP!!! CAR CUT OFF ON ME!!! (MaxPower)
Well thank God it's not just me!!!
I feel a little better now, and I'll check out that column lock bypass (not really sure what it is yet).
Thanks guys.
Old Jun 13, 2002 | 03:06 PM
AP's Avatar
AP
Default Re: HELP!!! CAR CUT OFF ON ME!!! (77-4speed)
COH - Corvettes of Houston Sells them now ...
Old Jun 13, 2002 | 03:07 PM
vette2001c5's Avatar
vette2001c5
Did you accidentally turn off the ignition switch? I've hit my a couple times with my knee.
Old Jun 13, 2002 | 03:26 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
This has nothing to do with column lock. When engine stops, the power steering stop.
Old Jun 13, 2002 | 03:28 PM
DannyT's Avatar
DannyT
Hello,
Same exact thing happend to me three weeks ago. Mine is A4 and all
I did was to slow down a little and it died.
I couldn't get a strait answer from the dealership as to what they did.
But from what I can understand, one of the plugs went bad and so the
computer was compensating for that so the excessive lean situation
caused my engine to stall.
Who in the world knows what the hell happened. I am really concerned.
Danny
Old Jun 13, 2002 | 03:40 PM
MaxPower's Avatar
MaxPower
Default Re: HELP!!! CAR CUT OFF ON ME!!! (DannyT)
Strange this seems to have happened to others. When mine did this it just died without warning. It was very odd to be driving one moment and then no power the next without any warning. I stick by theory had to have been aliens. :(
Old Jun 13, 2002 | 03:51 PM
Untouchable00's Avatar
Untouchable00
I'll cross my fingers here...
Old Jun 13, 2002 | 04:27 PM
Snafu's Avatar
Snafu
Default Re: HELP!!! CAR CUT OFF ON ME!!! (Untouchable00)
I spoke with the dealership...they actually seemed concerned and scheduled for me to bring it in first thing in the morning. I asked them what they planned to do...they said there was a fix for it and it would be $450 if it wasn't under warranty (I'm glad it is).
I'll let ya know if it works...I've heard it doesn't.
Old Jun 13, 2002 | 06:30 PM
MelloYellow's Avatar
MelloYellow
The problem described above is the engine stalling out on you, not Column Lock. Power steering shuts off with the engine.
This happens more often with Cam'd cars. Do you have an aftermarket cam?
Old Jun 14, 2002 | 01:35 AM
Snafu's Avatar
Snafu
Default Re: HELP!!! CAR CUT OFF ON ME!!! (MelloYellow)
Nope, no cam...only mods are the ones in my sig.
I don't think it was the engine stalling...I was running around 50mph, instead of downshifting, I just let it coast. The engine stayed on, I just couldn't steer. When I finally got to a stop, the engine died. Then I cranked it again.
I thought maybe a drop in voltage caused it (electric gremlin), but all my guages looked right. The fact that I was turning makes it seem like column lock. I guess I'll see when I get it back from the dealership tomorrow.
What do you guys think?
Old Jun 26, 2002 | 01:44 AM
numtin's Avatar
numtin
my problem, has actually gotten alot worse. the car died twice one me yesterday on a single trip around the block. i have replaced my plugs recently, is there a code or something to look for if a plug is bad?
Old Jun 26, 2002 | 06:47 AM
jandj's Avatar
jandj
my car is presently at the dealer due to the same problem. I just drive down the road and if I am in 2nd and starting to rev her up she then stalls out on me. Then it just got worse on the way to the dealer the freaking thing stalled out on me 15 times (dealer is 45 minutes away). amazingly it is hard to get a chevy dealer to do possible warranty work if you did not buy the chevy there. my car would not turn over at first though then fired up. Dealer as of right now has no idea what the problem is. stated they need my car for a week and won't give me a car. :mad :mad :mad :mad :mad :mad :mad :mad :mad :mad :mad
Old Jun 26, 2002 | 09:25 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Your stating misinformation dude... Nothing to do with the column lock :rolleyes: If you don't know don't guess for it could cost somone money they need not spend...
To HELP!!! CAR CUT OFF ON ME!!!
Old Jun 26, 2002 | 11:00 AM
jandj's Avatar
jandj
Default Re: HELP!!! CAR CUT OFF ON ME!!! (Smoke-N-Shot)
It cannot be the column lock bypass because the chevy dealer already did the recall for this on my car.
Old Jun 26, 2002 | 11:44 AM
JT-C6's Avatar
JT-C6
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Default Re: HELP!!! CAR CUT OFF ON ME!!! (jandj)
Look at the codes on the DIC. How is the dealer diagnosing a fix for $450 over the phone without even knowing what codes were thrown? You could have a sensor failure that throws a 1415 code for AIR valve that might you leave unable to start or only operate in reduced engine power mode.
Old Jun 26, 2002 | 11:05 PM
NassyVette's Avatar
NassyVette
Default Re: HELP!!! CAR CUT OFF ON ME!!! (TexasRedY2K)
Loose battery connection :yesnod:
