Where to get a helmet?
Old Jun 13, 2002 | 03:26 PM
Stingray1967's Avatar
Stingray1967
Default Where to get a helmet?
Ok guys, I'm interested in starting to autocross and I'm told I need a Snell 95 helmet. Where do I get one? Is $300 an average price for one?
Old Jun 13, 2002 | 03:31 PM
BAD2BNE's Avatar
BAD2BNE
Default Re: Where to get a helmet? (Stingray1967)
Here's the one I use....it seems to be the one that a lot of AutoX clubs have as loaners as well... Hope it helps some
http://www.simpsonracing.com/Shop/Sh...45&product=144
Old Jun 13, 2002 | 03:33 PM
AP's Avatar
AP
Default Re: Where to get a helmet? (BAD2BNE)
Thats the one our club uses ...
Old Jun 13, 2002 | 03:38 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Got mine from Bellmotorsports, under $200! http://www.bellmotorsports.com
Old Jun 13, 2002 | 04:14 PM
Stingray1967
Default Re: Where to get a helmet? (wallstAL)
Is this one ok? It goes for $120 and is Snell M95, is that the same thing as Snell 95?
Here's a link to it.
http://www.bellmotorsports.com/
Old Jun 13, 2002 | 04:25 PM
allanlaw's Avatar
allanlaw
Snell is either "M" for motorcycle or "SA" which is a higher rating with fire resistent lining. If you have any notion of trying road track events in the future, you should go with an SA2000 rated helmet, since that is what is being required or will soon be required by many organizers (you can still get by with SA95 but not for too much longer).
I went with a Bell Mag4 open face helmet, SA2000. It cost me around $179 from http://www.racerwholesale.com on a closeout. They also carry other reasonably priced SA2000 helmets.
Old Jun 13, 2002 | 04:31 PM
dangrass's Avatar
dangrass
The cheapest is racerwholesale....some suggestions:
1. Don't buy a Snell 95 helmet...get a Snell 98 helmet at this point. Various sanctioning bodies will begin mandating '98 stickered helmets so the '95 will have a limited life
2. Be aware of the differences between and SA helmet and an M helmet. If you want to run in certain events you MUST have an SA helmet, while most sanctioning bodies don't care which. An M helmet is much more useful for various things...like riding a motorcycle, snowmobile, motorized skateboard, etc. SA helmets usually cost more because they are made in smaller numbers
3. I don't recommend Bell Motorsports as their return/exchange policy is really lousy. While most folks will accept a return/exchange as a normal business event these guys are real sticklers about charging a 15% penalty irrespective of the circumstances. Bottom line is that you are better off dealing with a company that doesn't impose these hidden costs
Dan
Old Jun 13, 2002 | 04:41 PM
BAD2BNE's Avatar
BAD2BNE
Another reason I suggested the Simpson brand is that they are made for custom order if you order them direct from Simpson.
Suggestion: Go to a local AutoX event and try on a couple of the sizes of helmets they have as loaners so you can decide which size fits you comfortably without any excess movement of the helmet on yor head. Then either order or buy one that has a build date that will be very new. This will insure the most recent Snell Rating and will give you the longest life with the most comfortable, protective fit for your own use..
Don't cheat yourself out of quality on a helmet. The watermelon (head) you save will be yours :D :cheers:
Good luck
Old Jun 13, 2002 | 05:22 PM
Z06 Fletch's Avatar
Z06 Fletch
So I have been saving my old 95 motorcycle helmet for nothing? Well unless the wife lets me get another bike, but thats not likely to happen :rolleyes:
Old Jun 13, 2002 | 05:39 PM
allanlaw's Avatar
allanlaw
Default Re: Where to get a helmet? (dangrass)
There are no SA98 helmets - only SA95 and SA2000. It's the SA2000 you want.
Old Jun 13, 2002 | 05:50 PM
dangrass's Avatar
dangrass
Default Re: Where to get a helmet? (allanlaw)
allanlaw is right! I meant to say, "get a 2000...either SA or M, depending on ALL that you intent to use it for! (how time flies!)
Dan
Old Jun 13, 2002 | 05:55 PM
RedLandRocket's Avatar
RedLandRocket
Here is the rule for SCCA
4.3.1 Helmets
Helmets meeting the following standards must be worn while on course. All helmets meeting the current or two immediately preceding Snell Foundation standards (SA, M, or K) are acceptable. For 2002 this includes Snell 2000, Snell 1995, or Snell 1990.
Old Jun 13, 2002 | 06:07 PM
dangrass's Avatar
dangrass
Default Re: Where to get a helmet? (RedLandRocket)
SCCA is very reasonable (in this regard). If you want to run in the Silver State Classic they are mandating only SA helmets and are going to require SA2000's next year. The other high speed events have similar requirements.
The point of all this is to buy a helmet that gives you maximum utility for your intended use (s)...
Dan
Old Jun 14, 2002 | 12:30 AM
Stingray1967
Thanks for all the replies guys! Much appreciated. I love this place!
Old Jun 14, 2002 | 04:46 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
sIMPSON sNELL 2000
Old Jun 14, 2002 | 10:37 PM
Greg00Coupe's Avatar
Greg00Coupe
Default Re: Where to get a helmet? (John Shiels)
Go to your local motorcycle dealer. I go t a nice Bell 2000 for $95 on close out. Of course the $18,000 I spent on the new Harley for "just passing through" could make the helmet not such a bargain.
To Where to get a helmet?
