Battery keeps dieing?
Old Jan 29, 2013 | 06:17 AM
luc719's Avatar
luc719
Default Battery keeps dieing?
Ok i have a pritty big sound system in my vette and the battery keeps draining. i have upgraded all my engine wireing to "0" gauge, put in a capacitor, and got a yellow top deep cycle. what else can i do to prevent this? is there a upgrade for the alternator? please help!
Old Jan 29, 2013 | 07:44 AM
Cutlassmaster's Avatar
Cutlassmaster
Can you be more specific? Draining while running or off? If off, something is not shutting off in your system and is draining the battery. Most likely you will need to get out the multi-meter and start eliminating piece by piece. Once you give more specifics I am sure others will chime in.
GL
Chris
Old Jan 29, 2013 | 09:05 AM
99 vett babycar's Avatar
99 vett babycar
GL
Chris
Shut everything off, wait about 15 minutes and the measure your drain current. If its more than 20ma you've got something "on"that's drawing the battery down.
To Battery keeps dieing?
