Throttle body
Old Jan 29, 2013 | 08:13 PM
jfreez88's Avatar
jfreez88
Default Throttle body
I recently changed the heads on my 02 C5, I upgraded to the LS6 heads after one of the stock LS1 heads shot the #2 spark plug out and stripped the head. I'm wondering do I or should I change the throttle body to accompany the new heads, If so does anybody have any suggestions... Also what is the stock LS1 size and if I should change it what size should I go to.. Thanks
Old Jan 29, 2013 | 08:21 PM
superjet701k's Avatar
superjet701k
Ls1 = 78mm
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
If you are running the stock LS1 or LS6 intake manifold, then stay with the stock TB which is 78mm. If you want, have it ported and polished.
Old Jan 29, 2013 | 08:26 PM
NukeC5's Avatar
NukeC5
Yes, the stock TB is matched to the stock intake snout diameter. There is some to be gained by a p&p, but nothing like a FAST intake and 90mm LS2 TB or the like
Old Jan 29, 2013 | 08:31 PM
jfreez88's Avatar
jfreez88
So to go to a bigger TB I must also change manifold, I was looking at the FAST system.. Worth it??
jfreez88's Avatar
jfreez88
Also will any computer tuning need to be done?
Old Jan 29, 2013 | 08:35 PM
NukeC5's Avatar
NukeC5
Yes worth it, and yes tuning because you will be lean after the swap. I went from an LS6 intake tuned to the FAST92mm and LS2 P&P TB and picked up 15whp. On stock heads too. So you stand to gain allot.
Old Jan 29, 2013 | 08:45 PM
jfreez88's Avatar
jfreez88
Now for the big question.... I'm in sunny California,.. Will I have any problems with smog checks?
Old Jan 30, 2013 | 01:04 AM
NukeC5's Avatar
NukeC5
Yes, do like I did and keep your stock intake to swap back on in case.
To Throttle body
