Paging EHS : Export Foglight Question
Old Jun 14, 2002 | 08:32 AM
Harris's Avatar
Harris
Default Paging EHS : Export Foglight Question
I am going to replace the factory foglights on my 2001 with a set of GM export foglights that I got from Bob at Fitchner Chevrolet. I plan to swap them this weekend but haven't been able to check the connections to see if they match the factory wiring. Do I need to buy any connectors, or do they plug into existing wiring? Thanks for your help!
Old Jun 14, 2002 | 10:18 AM
George Cooper's Avatar
George Cooper
Default Re: Paging EHS : Export Foglight Question (Harris)
The install is very easy, especially from below if you remove the closeout panels, but you do need different connectors. Bob at Fitchner should be able to set you up, but failing that, any dealer should have them as well. Unfortunately, my shop manuals are at home, so I cannot give you the part number myself.
Old Jun 16, 2002 | 04:04 PM
Harris's Avatar
Harris
ttt
Old Jun 16, 2002 | 06:36 PM
99 Corvette's Avatar
99 Corvette
Did you go with higher watt bulbs for them? If so how high did you go and where did you get them?
Jerry
Old Jun 17, 2002 | 11:46 AM
George Cooper
Default Re: Paging EHS : Export Foglight Question (99 Corvette)
The stock bulbs are all you will want. Just remember to aim them properly after the install.
To Paging EHS : Export Foglight Question
